December 31, 2023, 04:44 |
SU2 Error - Writing array data failed
Ron Efrati
Rep Power: 3 |
Hello, I am running a few SU2 RANS simulations on a large problem (about 50M cells). At some of the simulations I encounter the error “writing data array failed” when writing a “.vtu” paraview file. It may happen both at the beginning of the simulation, when no previous output files have been written, or at the end of the simulations, when SU2 has already exported such output files. When I restart the simulation after the error occurs, it sometimes repeats itself, and sometimes it is not. I am running the simulations on a single node of a cluster server, and I have enough storage for the simulations.
Thank you for your help! |
December 31, 2023, 04:57 |
bigfoot
Rep Power: 18 |
does it happen when you write other paraview formats, like the legacy .vtk file or the multiblock .vtm file?
Does it only happen when you write .vtu files? |
December 31, 2023, 11:07 |
Ron Efrati
Rep Power: 3 |
I did not try to export paraview legacy files. I will test it with a few simulations and let you know if it happens soon. Currently, it only happens with paraview vtu files.
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 22:38 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 15:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
