SU2 Compressible Solver Freestream Vector Definition |
December 16, 2023, 15:51 |
Rep Power: 9 |
Is there a way to define an arbitrary freestream vector (i.e., [u, v, w]) for the compressible solver rather than alpha/beta? This adds complexity to the process when running cases that do not align with the SU2 coordinate frame.
December 19, 2023, 07:39 |
bigfoot
Rep Power: 18 |
I do not see how introducing [U,V,W] reduces complexity compared to working with [Ma,alpha,beta], since the usual measure of velocity is the Mach number for compressible flows.
It is not possible to work with freestream values [U,V,W] in SU2 (for compressible flows, it is possible for incompressible flow). |
January 5, 2024, 00:56 |
Rep Power: 9 |
The velocity magnitude could still be defined by Mach number, I'm referring to the direction of the velocity vector, [u/U, v/U, w/U] (defined as a normalized vector rather than two angles). Say you're working on a geometry with some X, Y, Z coordinate system and want the flow to be going in the negative X direction; currently that requires (as far as I know) defining an angle of attack of 180 degrees, and any angle of attack relative to that must be calculated WRT 180. The ability to define a normalized freestream vector, (e.g. something like [0.7071, 0.7071, 0]), would be more flexible for a wider variety of problems. Just a thought; I didn't see this functionality in the docs but wanted to check if it existed.
Static FSI with Compressible Flow (SU2 7.1.1) | sangeet | SU2 | 3 | April 4, 2021 16:28 |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Difference between Compressible CFD solver and Incompressible CFD solver | arijith | Main CFD Forum | 6 | September 23, 2012 19:23 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 18:06 |
