I need help with the discrete adjoint parameters |
December 16, 2023, 10:40 |
giuseppe sammarro
Hi, i'm using for the first time a discrete adjoint simulation, i've seen already all the tutorial and i have a few questions about the parameters that i have to insert on the config file.
1)the first one is relatively to the scale factor: % Optimization constraint functions with pushing factors (affects its value, not the gradient in the python scripts), separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= ( MOMENT_Z < 0.093 ) * 0.001; ( AIRFOIL_THICKNESS > 0.12 ) * 0.001 -What does change if i insert a lower or a higher number? -The scale factor needs to be the same also for the obj_function? if I insert a different number for example 0.1 for drag and 0.01 for the moment what can I expect? 2)DV_PARAM= ( 1, 0.5 ) what does this one? 3) the adjoint solutions in the folder DESIGN will always do the maximum number of iterations that i set in the config file? thanks for anyone who will try to explain me those question. |
Discrete adjoint cannot be run in parallel if variable load actuator disc model used | FabianBueeler | SU2 Shape Design | 1 | June 23, 2023 16:56 |
Solver parameters to solve convergence issue | WilliamH | SU2 | 5 | February 5, 2021 07:19 |
RANS discrete adjoint oscillating | pgdelaserna | SU2 | 3 | August 25, 2019 05:32 |
Discrete vs Continuous Adjoint solution variable: Scaling/normalization issue? | asitav | SU2 | 2 | November 21, 2018 20:11 |
Shape optimization doesn't converge - Adjoint log file | JPBLourenco | SU2 Shape Design | 0 | December 11, 2017 09:41 |
