Home > Forums > Software User Forums > SU2
UnitTests Geometry Error
Old   December 12, 2023, 12:24
Default UnitTests Geometry Error
cfd-jg is on a distinguished road
Hi, I have built SU2 v8.0.0 from source code and I am running the unit tests to check if it is working correctly using:
./UnitTests/test_driver
However, I get the following error with the geometry test.
j@j-GL553VD:~/SU2/Source/SU2-v8.0.0/build$ mpirun -n 2 ./UnitTests/test_driver
test_driver is a Catch v2.13.9 host application.
Run with -? for options
Geometry constructor
../UnitTests/Common/geometry/CGeometry_test.cpp:33
../UnitTests/Common/geometry/CGeometry_test.cpp:42: FAILED:
CHECK( aux_geometry->GetnPoint() == 125 )
with expansion:
62 == 125
../UnitTests/Common/geometry/CGeometry_test.cpp:43: FAILED:
CHECK( aux_geometry->GetnElem() == 64 )
with expansion:
42 == 64
../UnitTests/Common/geometry/CGeometry_test.cpp:44: FAILED:
CHECK( aux_geometry->GetnElemHexa() == 64 )
with expansion:
42 == 64
with expansion:
63 == 125
{Unknown expression after the reported line}
due to a fatal error condition:
SIGSEGV - Segmentation violation signal
with expansion:
43 == 64
with expansion:
43 == 64
test cases: 3 | 2 passed | 1 failed
assertions: 15 | 11 passed | 4 failed
[j-GL553VD:72783] *** Process received signal ***
[j-GL553VD:72783] Signal: Segmentation fault (11)
[j-GL553VD:72783] Signal code: (-6)
[j-GL553VD:72783] Failing at address: 0x3e800011c4f
[j-GL553VD:72783] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7fb4c3642520]
[j-GL553VD:72783] [ 1] ./UnitTests/test_driver(+0x6e1ae)[0x561664e0b1ae]
[j-GL553VD:72783] [ 2] ./UnitTests/test_driver(+0x8d77a)[0x561664e2a77a]
[j-GL553VD:72783] [ 3] ./UnitTests/test_driver(+0xa8edd)[0x561664e45edd]
[j-GL553VD:72783] [ 4] ./UnitTests/test_driver(+0xb66e1)[0x561664e536e1]
[j-GL553VD:72783] [ 5] ./UnitTests/test_driver(+0xbb508)[0x561664e58508]
[j-GL553VD:72783] [ 6] ./UnitTests/test_driver(+0xbba7c)[0x561664e58a7c]
[j-GL553VD:72783] [ 7] ./UnitTests/test_driver(+0x5e27e)[0x561664dfb27e]
[j-GL553VD:72783] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7fb4c3629d90]
[j-GL553VD:72783] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7fb4c3629e40]
[j-GL553VD:72783] [10] ./UnitTests/test_driver(+0x65565)[0x561664e02565]
[j-GL553VD:72783] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
SIGTERM - Termination request signal
assertions: 17 | 13 passed | 4 failed
mpirun noticed that process rank 1 with PID 0 on node jaime-GL553VD exited on signal 11 (Segmentation fault).
Any ideas on how to solve this?
Thanks for the help in advance
cfd-jg is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
