Home > Forums > Software User Forums > SU2
SU2 Adjoint shape optimization
Old   December 11, 2023, 09:38
Default SU2 Adjoint shape optimization
cfd-jg is on a distinguished road
I have downloaded the compiled version of SU2 v.8.0.0 on Ubuntu 20.04. I am following the constrained shape design of a transonic inviscid wing at a cte. CL: https://su2code.github.io/tutorials/...ained_ONERAM6/
In the goals section says this:
"The following SU2 tools will be showcased in this tutorial:
  • SU2_CFD - performs the direct flow simulations.
  • SU2_CFD_AD - performs the adjoint flow simulations.
  • SU2_DOT_AD - projects the adjoint surface sensitivities into the design space to obtain the gradient.
  • SU2_DEF - deforms the geometry and mesh with changes in the design variables during the shape optimization process.
  • SU2_GEO - evaluates the thickness of the specified wing stations and their gradients.
  • shape_optimization.py - automates the entire shape design process by executing the SU2 tools and optimizer."
However, I have realised that the SU2_CFD_AD and SU2_DOT_AD tools are not in the compiled version. Does this mean that I need to compile the source code by myself to be able to use adjoint shape optimization?
If this is the case, how can I do this? I have already tried following the tutorial on the website but it is not very detailed and I always end up with some type of error.
Thank you for the help.
cfd-jg is offline   Reply With Quote
Old   December 11, 2023, 10:41
bigfoot
bigfootedrockmidget is on a distinguished road
yes.
If you are currently working in windows, then switch to linux. Windows is not a research/development environment.
bigfootedrockmidget is offline   Reply With Quote
Old   December 11, 2023, 12:02
Originally Posted by bigfootedrockmidget View Post
yes.
I am using Ubuntu 20.04, still need to build the code from source?
Old   December 11, 2023, 14:04
bigfoot
In linux, just compile with AD support:
-Denable-autodiff=true
https://su2code.github.io/docs_v7/Bu...2-Linux-MacOS/
Optimization of airfoil Gradient based optimization SU2 ryupuriwat SU2 0 March 30, 2023 11:46
Shape optimization doesn't converge - Adjoint log file JPBLourenco SU2 Shape Design 0 December 11, 2017 09:41
SU2 Shape optimization questions AdriC SU2 Shape Design 6 January 27, 2016 05:25
Question about SU2 optimization YoniHe SU2 Shape Design 3 January 15, 2016 01:31
hard to convergent with SU2 4.0 for Euler adjoint Xianguu SU2 1 July 14, 2015 18:09
