The order of magnitudes of output-PPRIME is wierd. |
Zhang
Rep Power: 3 ![]() |
Hi,everyone.
I am currently seeking to obtain the mean fluctuating pressure in my simulation, and I have observed that the volume outputs provide a variable labeled "PPRIME," which seems to align with my requirements. However, I've noticed that the order of magnitudes for PPRIME appears unusual. My freestream pressure is 2500 Pa, and the Mach number is 6, whereas PPRIME exhibits magnitudes on the order of 10^8 or even larger. I am inclined to believe that SU2 might not be applying a root treatment to PPRIME. I would appreciate your insights on this matter. Furthermore, if there is a convenient method to extract the pulsation characteristics of the flow, I would be grateful for your guidance. Thank you for your patience and assistance. Best regards, Zhang. |
bigfoot
Rep Power: 17 ![]() |
Yes, pprime is p' * p' So it should actually be called PPPrime,, just like we have UUPRIME and UVPRIME But we also have RMS_P as output. |
Zhang
Hi, Midget
Thanks for your patient reply, it helps me a lot.I have a follow-up question regarding RMS_P, the order of magnitudes is 10^6 to 10^11. As I suspect it may not involve the square root operation, or it could potentially represent the RMS of total pressure. Thank you once again for your assistance. |
SU2 incompressible laminar flow | mkulcsar | SU2 | 3 | April 30, 2023 22:59 |
Optimization of airfoil Gradient based optimization SU2 | ryupuriwat | SU2 | 0 | March 30, 2023 10:46 |
Change Design Variables | Zahra_m | SU2 | 2 | July 21, 2022 17:58 |
Harmonic balance method for calculating multi-stage turbines | HIT19B902072 | SU2 | 2 | April 24, 2022 01:31 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
