December 7, 2023, 06:15 |
[NEMO] Non-physical points
Jesslyn Ong
Rep Power: 2 |
Hi to my SU2 peers! I am trying to reproduce the "Slip flow over a cylinder" case from https://doi.org/10.3390/aerospace8070193 as an intro to NEMO but I am facing stability issues with non-physical points while solving. I've tried all tons of meshes fine to coarse, stretched to non-stretched within different shapes of enclosure under different conditions. Some of the grids work well but the results are not ideal with huge error gap and I wonder if I've implemented the Maxwell slip incorrectly. So I would like to ask if anyone would be able to give a piece of advice. Thank you in advance!^^
Files: https://drive.google.com/drive/folde...57?usp=sharing |
nemo, non equilibrium flow |
Sample utility bug? For many cloud points in the sampleDict, some are neglected! | brandius | OpenFOAM Post-Processing | 10 | August 22, 2022 09:56 |
[Gmsh] Cannot transfer physical surfaces to patches inside the boundary file | celestial | OpenFOAM Meshing & Mesh Conversion | 3 | November 25, 2019 15:58 |
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
