Home > Forums > Software User Forums > SU2
I have a problem in restart_flow.dat
Old   December 6, 2023, 10:03
Default I have a problem in restart_flow.dat
David wang
David wang is on a distinguished road
I encountered the following error while working on the "Constrained shape design of a transient turbine air at a cte. CL" case. I tried opening restart_ Flow.dat file, but cannot be opened.
error:
Reading and storing the solution from restart_flow.
Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)":
No coordinates found in the restart file!!
------------------------------ Error Exit -------------------------------
18042 triangles.
4800 quadrilaterals.
18042 triangles.
Identify vertices.
Storing a mapping from global to local point index.
Identify vertices.
------------------------- Solution Postprocessing -----------------------
Identify vertices.
Identify vertices.
18042 triangles.
Identify vertices.
David wang is offline   Reply With Quote
Old   December 6, 2023, 10:07
David wang
my Ubuntu can't open ".dat" file. I don't know why?
When I tried to open the. dat file, it said "Could Not Display solution flow. dat
The file is of an unknown type”
Old   December 6, 2023, 11:29
bigfoot
bigfootedrockmidget is on a distinguished road
Do you have the files for us to reproduce this issue?
bigfootedrockmidget is offline   Reply With Quote
Old   March 1, 2024, 23:12
Default I have the same problem as Wang
Tongtong
Tongtong1919 is on a distinguished road
dear bigfootedrockmidget
I am encountering the same issue as Wang Dawei when attempting to run the SU2 official case "Constrained shape design of a transonic turbulent airfoil at a constant CL" (https://su2code.github.io/tutorials/...ained_RAE2822/) using SU2 version 8.0.0. I am operating on the WSL Ubuntu-22.04 platform. In the attachments, I will provide the log files. I seek your assistance in resolving this matter.
Tongtong1919 is offline   Reply With Quote
su2 8.0.0
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
