November 11, 2023, 09:07 |
SU2 Simulation of Rotor in Hover
Bakhshi Mehul
Rep Power: 3 |
Hello
I am trying to do simulation of a rotor in SU2, using rotating frame reference. However the solution is diverging. I am new to SU2, and unable to figure out the problem in my configuration file. The simulation is converging for the same solver if the rotor is not rotating. I am attaching the configuration file for the reference. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % % SU2 configuration file % % Case description: Caradonna & Tung rotor in hover (still air) % % Author: Thomas D. Economon % % Institution: Stanford University % % Date: 2020.05.24 % % File Version 8.0.0 "Harrier" % % % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % SOLVER= RANS KIND_TURB_MODEL= SA MATH_PROBLEM= DIRECT RESTART_SOL= NO % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % MACH_NUMBER= 0.00 AOA= 90.0 SIDESLIP_ANGLE= 90.0 %FREESTREAM_PRESSURE= 101325.0 FREESTREAM_TEMPERATURE= 288.15 REYNOLDS_NUMBER= 0.94778E6 REYNOLDS_LENGTH= 0.114 % --------------------------- VISCOSITY MODEL ---------------------------------% % VISCOSITY_MODEL= SUTHERLAND MU_CONSTANT= 1.716E-5 MU_REF= 1.716E-5 MU_T_REF= 273.15 SUTHERLAND_CONSTANT= 110.4 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % REF_ORIGIN_MOMENT_X = 0.00 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 REF_LENGTH= 0.114 REF_AREA= 00.0 % ----------------------- DYNAMIC MESH DEFINITION -----------------------------% % GRID_MOVEMENT= ROTATING_FRAME MACH_MOTION= 0.174 MOTION_ORIGIN= 0.0 0.0 0.0 ROTATION_RATE = 0.0 -523.598775 0.0 % 1250 RPM -> 130.89969389957471 % 2500 RPM -> 261.79938779914943 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % MARKER_HEATFLUX= ( ROTOR, 0.0 ) MARKER_FAR= ( FARFIELD ) MARKER_PLOTTING= ( ROTOR ) MARKER_MONITORING= ( ROTOR ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % NUM_METHOD_GRAD= GREEN_GAUSS CFL_NUMBER= 1000 CFL_ADAPT= NO CFL_ADAPT_PARAM= ( 0.1, 2.0, 15, 1e6 ) RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) ITER= 99999 % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % LINEAR_SOLVER= FGMRES LINEAR_SOLVER_PREC= ILU LINEAR_SOLVER_ERROR= 1E-10 LINEAR_SOLVER_ITER= 10 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % MGLEVEL= 0 MGCYCLE= W_CYCLE MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) MG_POST_SMOOTH= ( 0, 0, 0, 0 ) MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) MG_DAMP_RESTRICTION= 0.9 MG_DAMP_PROLONGATION= 0.9 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % CONV_NUM_METHOD_FLOW= JST MUSCL_FLOW = NO JST_SENSOR_COEFF= ( 0.5, 0.02 ) TIME_DISCRE_FLOW= EULER_IMPLICIT % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % CONV_NUM_METHOD_TURB= SCALAR_UPWIND MUSCL_TURB= NO SLOPE_LIMITER_TURB= NONE TIME_DISCRE_TURB= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % CONV_FIELD= RMS_DENSITY CONV_RESIDUAL_MINVAL= -6 CONV_STARTITER= 10 CONV_CAUCHY_ELEMS= 100 CONV_CAUCHY_EPS= 1E-10 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % MESH_FILENAME= rotor3.su2 MESH_FORMAT= SU2 MESH_OUT_FILENAME= mesh_caradonna_tung_periodic.su2 SOLUTION_FILENAME= solution_flow.dat SOLUTION_ADJ_FILENAME= solution_adj.dat TABULAR_FORMAT= CSV CONV_FILENAME= history RESTART_FILENAME= restart_flow.dat RESTART_ADJ_FILENAME= restart_adj.dat VOLUME_FILENAME= flow VOLUME_ADJ_FILENAME= adjoint GRAD_OBJFUNC_FILENAME= of_grad.dat SURFACE_FILENAME= surface_flow SURFACE_ADJ_FILENAME= surface_adjoint OUTPUT_WRT_FREQ= 100 SCREEN_OUTPUT=(INNER_ITER, WALL_TIME, RMS_DENSITY, LIFT, DRAG, AVG_CFL) The error on the terminal is Error in "void CSolver::SetResidual_RMS(const CGeometry*, const CConfig*)": ------------------------------------------------------------------------- SU2 has diverged (NaN detected). ------------------------------ Error Exit ------------------------------- Thank you for the help. Last edited by Bakhshi; November 14, 2023 at 03:44. |
SU2 result in divergency | zhang-qiang | SU2 | 12 | March 18, 2023 22:09 |
write bc data and read it for other simulation | jdp810 | SU2 | 1 | May 8, 2021 18:04 |
Problem with cfg file for SU2 simulation over airfoil | Milz | SU2 | 1 | April 18, 2021 18:50 |
Unstaedy Simulation of ramp up motion of airfoil in su2 | Vivek Satheesh | SU2 | 1 | March 28, 2019 06:58 |
Incompressible simulation | brugiere_olivier | SU2 | 2 | April 15, 2014 11:12 |
