How to write output data for a specific cell (ExtractSelection) |
Vivek kumar
Rep Power: 5 ![]() |
Dear All,
As I am interested to write a particular cell data from the whole domain in SU2 code, because When I am writing the data for a full domain it is taking too much time and memory. Can anyone please help me to do this ? Thanks in advance regards Vivek Kumar, India Last edited by vivekdixit194; November 9, 2023 at 07:40. |
bigfoot
Rep Power: 17 ![]() |
You can add monitoring points, which are called probes in SU2.
The documentation is here: https://su2code.github.io/docs_v7/Custom-Output/ You could do this to output the velocity in a point P(0.1, 0.2, 0.3): Code:
CUSTOM_OUTPUTS='velocity : Macro{sqrt(pow(VELOCITY_X, 2) + pow(VELOCITY_Y, 2) + pow(VELOCITY_Z, 2))};\ point1 : Probe{$velocity}[0.1, 0.2, 0.3]' |
Vivek kumar
Dear,
Thanks a lot for your response. I was using the same documents given in the SU2 webpage but It is giving error. I have used CUSTOM_OUTPUTS= 'velocity : Macro{sqrt(pow(VELOCITY_X, 2) + pow(VELOCITY_Y, 2) + pow(VELOCITY_Z, 2))};\ avg_vel : AreaAvg{$velocity}[z_minus, z_plus];\ var_vel : AreaAvg{pow($velocity - avg_vel, 2)}[z_minus, z_plus];\ dev_vel : Function{sqrt(var_vel) / avg_vel};\ probe1 : Probe{$velocity}[0.005, 0.005, 0.05]' But the error in the terminal is shown as Error in "void CFlowOutput::ConvertVariableSymbolsToIndices(const CPrimitiveIndices<long unsigned int>&, bool, COutput::CustomOutput&) const": ------------------------------------------------------------------------- Invalid history output or solver variable (VELOCITY_Z) used in function avg_vel Valid solvers variables: CP_TOTAL DENSITY EDDY_VISCOSITY LAMINAR_VISCOSITY PRESSURE SOUND_SPEED TEMPERATURE THERMAL_CONDUCTIVITY VELOCITY_X VELOCITY_Y TURB[0,1,...] RAD[0,1,...] SPECIES[0,1,...] SCALAR[0,1,...] ------------------------------ Error Exit ------------------------------- I would like to tell you that I am interested in finding out the temperature for a specific point and dont want to write the temperature for all the domain. Thanks in advance |
Vivek kumar
If I am removing the Z points from the probe, still not writing the specific cell data. Still writing the whole domain data without any error.
bigfoot
Where are you looking?
Vivek kumar
Dear,
I am adding few lines as suggested by you in my config file, CUSTOM_OUTPUTS= 'velocity : Macro{sqrt(pow(VELOCITY_X, 2) + pow(VELOCITY_Y, 2))};\ avg_vel : AreaAvg{$velocity}[z_minus, z_plus];\ var_vel : AreaAvg{pow($velocity - avg_vel, 2)}[z_minus, z_plus];\ dev_vel : Function{sqrt(var_vel) / avg_vel};\ probe1 : Probe{$velocity}[0.1032, 0.8036]' SCREEN_OUTPUT= INNER_ITER, RMS_DENSITY, RMS_ENERGY, LINSOL_RESIDUAL, FORCE_Z,\ SURFACE_MASSFLOW, SURFACE_TOTAL_TEMPERATURE, avg_vel, dev_vel, probe1, COMBO HISTORY_OUTPUT = ITER, AERO_COEFF, FLOW_COEFF, FLOW_COEFF_SURF, CUSTOM, COMBO OBJECTIVE_FUNCTION= CUSTOM_OBJFUNC CUSTOM_OBJFUNC= 'SURFACE_TOTAL_TEMPERATURE' But After running my code, Still It is writing Whole volume file as I am not interested in writing the values for all the domain. Please help me to write only cell data because it is taking 4MB file for a single iteration. |
Vivek kumar
Dear,
Can you please help me to write only probe data ? CUSTOM_OUTPUTS='temperature : Macro{TEMPERATURE};\ probe1 : Probe{$temperature}[0.1032, 0.8036]' |
bigfoot
I meant in which output file are you looking, it seems that you are looking in the volume output file, but the custom output is written to the history file.
#9 |
Bihar
Rep Power: 3 ![]() |
Dear,
Got it. Thank you so much for your help. |
#10 |
Vivek kumar
Dear,
I am getting Error. Error in "void COutput::ComputeSimpleCustomOutputs(const CConfig*)": ------------------------------------------------------------------------- The current solver can only use 'Function' custom outputs. ------------------------------ Error Exit ------------------------------- I am using MULTIPHYSICS solver and trying to write the files in ELASTICITY Solver. Why i am getting this error ?. Please help me to fix this. thanks in advance |
su2 7.2.0 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 04:46 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
