Time per iteration increases for large problems |
Ron Efrati
Rep Power: 3 ![]() |
I am using SU2 for simulations at transonic Mach numbers. I have encountered an increase in time per iteration for large problems (50M+ cells). For example, I found that at the beginning of the simulation it took 20s per iteration, but after about 1000 iterations it took 50s per iteration. I suspected that the number of iterations needed for the convergence of the linear solver increases with time, so I exported LINSOL as screen output. However, I found out that at all times the linear solver converged after 6 iterations. It is worth mentioning that when I restart the simulation from previous iteration, the time per iteration reverts back to 20s from 50s. Has anyone encountered this problem before? Thank you. |
Pedro Gomes
Rep Power: 13 ![]() |
No this seems odd. Can you share the config, version of the code, etc. Can you monitor how much memory is being used and if it increases in time?
Ron Efrati
Documents.zipHi, of course, the input file and the corresponding output are attached. You can see that the time per iteration increases dramatically. As I mentioned before, when I restart the simulation the time reduces back to normal. Lately I found out that when I run an unsteady simulation, the time reduces back at each time iteration, namely it only increases with inner iterations. The output of the unsteady simulation is attached as well. I used version 7.5.1. I did not check the memory usage during the simulation, but it stands close to 50% at most times (I run the simulation on a shared memory machine).
bigfoot
Rep Power: 17 ![]() |
Do you have the su2 mesh as well?
Ron Efrati
Convergence problem of OF | WUYing | OpenFOAM Running, Solving & CFD | 2 | September 20, 2021 10:09 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
