Long geometry preprocessing time for a large amount of cpus |
Rep Power: 4 ![]() |
I am trying to run a simulation of 70M cells, and for that reason I need to use at least 128 cores (16 cores per cpu) on my server to get reasonable time per iteration. The problem is, when I try to use that many cores the geometry preprocessing takes a very long time (3 hours at least..). Is it possible to run only the geometry preprocessing on a smaller number of cores (so it finishes more quickly) and then load the partitioned mesh to the solver later? Thank you |
bigfoot
Rep Power: 17 ![]() |
That doesn't sound right. Can you tell a bit more about the case? Which part of the preprocessing takes so much time?
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
[waves2Foam] Long waiting time for large number of gauges | katakgoreng | OpenFOAM Community Contributions | 1 | January 21, 2015 15:34 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
