Divergence Problem in supersonic Laminar flow over a flat plate |
Sean
Rep Power: 3 ![]() |
My solution is diverged when I run Supersonic Laminar flow over a flat plate. It converges till I use Mach = 0.6 but diverges after that. I tried to reduce CFL number, tried different numerical methods also, but it diverges after Mach 0.6. What could be possible error ? I am also attaching my cfg file, could you please take a look !
bigfoot
Rep Power: 17 ![]() |
You could try restarting from a converged solution where you used a lower velocity, or use a different initial condition.
You could also try running it with a turbulence model, I could get a similar case running with INC_RANS + SA for Ma=2.0 |
#3 | |
Guangjing JU
I think the supersonic down stream pressure should not be specified, but SU2 seems not to provide such boundary condition, and i am very confused. |
SU2 incompressible laminar flow | mkulcsar | SU2 | 3 | April 30, 2023 22:59 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
laminar flow over a flat plate blasius comparison | preetam69 | FLUENT | 0 | September 23, 2013 21:33 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
Supersonic flow over a flat plate and a blunt body. | Maddy | FLUENT | 0 | August 31, 2010 16:35 |
