Home > Forums > Software User Forums > SU2
Fluctuation in Pressure distribution over the airfoil
Old   July 25, 2023, 13:04
Default Fluctuation in Pressure distribution over the airfoil
Amit
asinghk is on a distinguished road
I am trying to simulate incompressible flow over NACA 2412. At the frond leading and trailing edge, I am getting fluctuation in pressure. I am new to this and could not figure out the reason whether it is mesh of numerical scheme?
asinghk is offline   Reply With Quote
Old   July 26, 2023, 04:27
bigfoot
bigfootedrockmidget is on a distinguished road
Do the residuals converge to machine precision? That's the first thing to check. If they get stuck at a high residual, then you first have to make it converge.
Is it convergence?
-> Lower CFL, improve mesh, switch to different numerical scheme
Is it the mesh?
-> Refine the mesh, reduce y+, increase nr. of cells overall, increase mesh quality and you will know the impact of mesh refinement and quality improvement
Is it the numerical scheme?
-> Switch to a different numerical scheme: MUSCL on/off, green-gauss or Weighted LEst Squares and you will know the impact of the numerical scheme
bigfootedrockmidget is offline   Reply With Quote
airfoil analysis, mesh, numerical schemes
Total pressure distribution at boundary as a named expression ftopper FLUENT 0 December 9, 2022 10:23
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
Pressure distribution around airfoil stater OpenFOAM Post-Processing 4 April 26, 2013 07:56
Airfoil pressure distribution kanishkpanchal Main CFD Forum 2 December 7, 2009 14:21
