Start the unsteady computation based on the steady simulation results |
July 22, 2023, 10:36 |
Zhang
Rep Power: 3 |
I want to start the unsteady computation based on the steady simulation results, which I think can reduce the simulation time. I think the restart can help. But As far as I konw, the unsteay restart read the first two steps of the present step, while the steady simulation only output one restart profile.So is there any solution that can start the unsteady computation based on the steady results? |
July 22, 2023, 18:12 |
bigfoot
Rep Power: 21 |
2nd order (DUAL_TIME_STEPPING-2ND_ORDER) needs 2 time steps,
1st order (DUAL_TIME_STEPPING-1ST_ORDER) needs 1 time step. But you can copy the existing restart.dat to solution_00000.dat and solution_00001.dat to restart with a 2nd-order method. |
July 22, 2023, 23:23 |
Zhang
Rep Power: 3 |
Thank you for your generous help, I will try it again.
Solving coupled steady and unsteady equation in OpenFOAM | jd87 | OpenFOAM Running, Solving & CFD | 2 | July 22, 2020 12:36 |
Adding heat source to chtMultiRegionFoam | maddalena | OpenFOAM Programming & Development | 61 | February 17, 2018 09:33 |
use unsteady computation results to other compute | turbinesv | CFX | 2 | October 12, 2008 09:55 |
Backup results in steady simulation | Li | CFX | 0 | July 9, 2007 06:39 |
steady or unsteady? (in dpm) | winnie | FLUENT | 1 | April 28, 2003 12:30 |
