Issue with structural analysis combined with turbomachinery |
Lorenz
Rep Power: 3 ![]() |
Dear Community,
Description i am trying to couple a rotor-stator turbomachine simulation (mixing plane approach) with a structural analysis. It would be enough for me to do the fluid simulation and do a structural analysis afterwards, by using the values on the blades (fluid load). However i do not know how to extract those values and provide them as input for the structural analysis. So far i have tried to follow the example given for "fsi" to set the structural and fluid interface. https://github.com/su2code/Tutorials...ics/steady_fsi I know this couples the flow with mesh deformation, which i don't particular need but is the only tutorial i found so far. Excellent would be to have two cases:
I have set up one main file and three sub files (rotor_fluid, stator_fluid, rotor_blade). The main file includes the coupling of the zones. However, when starting the simulation, I observe that the solver tries to set a mixing plane for the solid as well, even though there is no mixing plane interface defined. Software Specification I am using SU2 7.5.1. on a wsl ubuntu system 20.04 I have attached the log and the config files I am using. I can provide the mesh files if needed. best regards,
Lorenz H. PhD Student Montanuniversity Leoben |
fsi, structural, turbomachinery |
Adding 1D element in structural analysis. | Pegasos | Structural Mechanics | 0 | February 23, 2017 20:16 |
ANSYS Static Structural Visualization Issue | raunakbardia | Structural Mechanics | 1 | October 11, 2015 03:10 |
Patch types for structural analysis? | pad | OpenFOAM Running, Solving & CFD | 0 | February 11, 2013 08:30 |
FSI: fluid - structural analysis, help plz | emreg | ANSYS | 0 | December 19, 2011 12:41 |
Turbomachinery Convergence Issue CFX 11 | sherifkadry | CFX | 0 | May 29, 2009 13:07 |
