Home > Forums > Software User Forums > SU2
Questions about unsteady restart simulation.
Old   June 27, 2023, 00:44
Default Questions about unsteady restart simulation.
Zhang
Amber0922 is on a distinguished road
I have run an unsteady simulation, and to save the storage space, I set " OUTPUT_WRT_FREQ= 100, 100, 100 ", so the restart flow date is 100, 200, and so on. At the same time, I set "WINDOW_START_ITER = 100 " to get the time average variables.
But when I want to restart the solution, I set "RESTART_SOL= YES" and "RESTART_ITER=102", I hope it can read the 100 flow. but it said "Unable to open SU2 restart file restart_flow_00101.dat". Unfortunately, I didn't restore the 101 date, my storage is 100, 200 and ....
So, what can I do to restart the simulation from the 100 or any other flow which I saved. Any help is important for me, thanks in advance.
Amber0922 is offline   Reply With Quote
Old   June 27, 2023, 19:17
pcg
Pedro Gomes
pcg is on a distinguished road
The best you can do is to do one time step with first order in time, and then restart again with second order in time.
The second best is to make a copy of the file you have.
You are probably using an old version because we made this more friendly recently and now the solver outputs two files when necessary.
pcg is offline   Reply With Quote
Old   June 27, 2023, 22:32
Zhang
Hi,Pedro
My version is 7.5.1, I'm not sure if it has the feature that you said. But it exactly saved the restart_flow_100, restart_flow_199, restart_flow_200 and so on. So should I set the restart begin at 198? Or run the simulation again?
Best wishes.
Old   June 27, 2023, 23:32
Zhang
And another bewilderment is that when I set RESTART_ITER=99, it seems to find the 97 flow and restart with it. In my opinion, it should find the 100 and run that. So , does the restart simulation begin the iteration at the 97, if I set RESTART_ITER=99?
Old   June 28, 2023, 11:09
pcg
Pedro Gomes
If you start at iteration "n" you need files "n-1" and "n-2"
Old   June 28, 2023, 23:24
Zhang
I realized that I had misunderstood the difference between steady and unsteady restart simulations, thanks to your patience, everything has been resolved.
Old   June 28, 2023, 23:37
Zhang
Problem with restart in FSI unsteady simulation david_mocholi SU2 1 June 24, 2023 07:06
Simulation beginning from initialized solution rather than restart file eskimmel SU2 2 June 19, 2023 11:03
Unable to correctly restart a simulation that has stopped. feuille OpenFOAM Running, Solving & CFD 4 June 15, 2023 17:17
Unsteady simulation of rotating duct SRF or Sliding mesh Alisa_W FLUENT 7 January 22, 2019 07:34
How to see temperature and velocity vector contour after unsteady simulation? aja1345 FLUENT 3 September 24, 2018 17:33
