mpi4py.MPI.Status size changed, may indicate binary incompatibility |
June 17, 2023, 07:00 |
Mag
Rep Power: 5 |
I compiled SU2-7.3.1 with following configuring options on our institute supercomputer to an FSI example. The supercomputer runs on Linux OS based on CentOS 7.x distribution.
-Dcustom-mpi=true -Denable-mkl=true -Dmkl_root=/home-ext/apps/spack/opt/spack/linux-centos7-cascadelake/intel-19.0.5.281/intel-mkl2020.4.304-fet6h2j2qeq5alsxjiw7fzjkweqorbjf/mkl/ -Denable-pywrapper=true SU2-7.3.1 is compiled with following packages. gcc 11.2.0 mpi4py 3.0.3 openmpi 4.1.2 python 3.9.10 swig 4.0.2 The compilation was done successfully. Now, I am checking the code by running the following FSI example on the cluster. https://github.com/su2code/Tutorials...si_python/Ma01 I checked this example in serial and parallel. I am getting following error. ValueError: mpi4py.MPI.Status size changed, may indicate binary incompatibility. Expected 48 from C header, got 40 from PyObject This will be a great help. I have been struggling to run this example on the cluster for so long. Any help will work for me. Please help and suggest. Thank you |
June 17, 2023, 10:55 |
bigfoot
Rep Power: 21 |
I think this is a mismatch between mpi and mpi4py. Does a regular mpi job without the python wrapper work (it runs correctly and scales with nr of cores)? Do you have different mpi4py versions available (maybe through modules)? If so, you could try with a different version.
June 24, 2023, 07:52 |
Mag
Rep Power: 5 |
Yes, I was able to run only a CFD problem without FSI. Do you have different mpi4py versions available (maybe through modules)? If so, you could try with a different version.[/QUOTE] Yes, I installed SU2-7.5.1 with the following versions. Now, fsi is working. gcc v12.2.0 mpi4py v3.1.4 python v3.10.8 openmpi v4.1.5 swig v4.1.1 numpy v1.24.0 scipy v1.5.4 rtree v1.0.1 petsc4py v3.16.0 But I am unable to restart the following example after 500 steps. It runs fine when I start it from scratch. https://github.com/su2code/Tutorials...si_python/Ma01 It produces the following error. ------------------------- File "/scratch/asemagan/exctbls/su2/su2-751_gcc1220py3108ompi415/bin/SU2_Nastran/pysu2_nastran.py", line 784, in __setRestart if int(line[1])==(self.Config["RESTART_ITER"]-2): KeyError: 'RESTART_ITER' ------------------------------------ |
June 24, 2023, 08:24 |
#4 | |
bigfoot
Rep Power: 21 |
looks like it did not find the keyword restart_iter:
July 1, 2023, 09:54 |
Mag
Rep Power: 5 |
To restart FSI example, we need fluid.cfg, solid.cfg, fsi.cfg cofig. files with mesh and two restart files (for second-order dual-time stepping). What I observed to resolve this error, provided that transient steps for fluid are completed, means "TIME_TRESHOLD" steps have already been done.
Suppose, your flow restart files are as follow. restart_flow_999.dat restart_flow_1000.dat Then you set following in fsi.cfg. TIME_TRESHOLD= -1 RESTART_ITER= 1001 RESTART_SOL= YES Then you set following in fluid.cfg. RESTART_ITER= 1001 RESTART_SOL= YES Then you set following in solid.cfg. RESTART_SOL= NO This is how the problem is resolved for me. |
fsi simulation |
[snappyHexMesh] stringing of feature edges | Hr_kules | OpenFOAM Meshing & Mesh Conversion | 0 | July 22, 2022 09:30 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
Issues with poor performance in faster CPU | gian93 | Hardware | 9 | October 29, 2018 14:34 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
