June 13, 2023, 00:37 |
Unsteady simulated divergence
Zhang
Rep Power: 3 |
I recently ran an unsteady simulation of a backward-facing step, but it diverged after 2993 steps with the error message "SU2 has diverged (NaN detected)" in the function "void CSolver::SetResidual_RMS(const CGeometry*, const CConfig*)". I have tried modifying my configuration, but to no avail. Could you please help me identify what went wrong? Thank you so much for your time and assistance. % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) SOLVER= RANS KIND_TURB_MODEL= SA HYBRID_RANSLES= SA_EDDES % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Axisymmetric simulation, only compressible flows (NO, YES) AXISYMMETRIC= NO % % Restart solution (NO, YES) RESTART_SOL= NO % % System of measurements (SI, US) % International system of units (SI): ( meters, kilograms, Kelvins, % Newtons = kg m/s^2, Pascals = N/m^2, % Density = kg/m^3, Speed = m/s, % Equiv. Area = m^2 ) % United States customary units (US): ( inches, slug, Rankines, lbf = slug ft/s^2, % psf = lbf/ft^2, Density = slug/ft^3, % Speed = ft/s, Equiv. Area = ft^2 ) SYSTEM_MEASUREMENTS= SI % % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % MACH_NUMBER= 0.128 AOA= 0.0 SIDESLIP_ANGLE= 0.0 FREESTREAM_TEMPERATURE= 289 FREESTREAM_VELOCITY= ( 44.2, 0.00, 0.00 ) REYNOLDS_NUMBER= 36000 REYNOLDS_LENGTH= 0.0127 % % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 0 % % ------------------------- UNSTEADY SIMULATION -------------------------------% TIME_DOMAIN= YES TIME_MARCHING= DUAL_TIME_STEPPING-2ND_ORDER TIME_STEP= 3E-6 %MAX_TIME= 9E-2 UNST_CFL_NUMBER= 0.0 INNER_ITER= 30 TIME_ITER = 10000 % Iteration number to begin unsteady restarts RESTART_ITER= 1000 %Time iteration to start the windowed time average in a direct run WINDOW_START_ITER = 200 % Window used for reverse sweep and direct run. Options (SQUARE, HANN, HANN_SQUARE, BUMP) Square is default. WINDOW_FUNCTION = SQUARE % % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( STEP, 0.0, UPPERWALL,0.0, LOWERWALL,0.0 ) % % Read inlet profile from a file (YES, NO) default: NO SPECIFIED_INLET_PROFILE= NO % % File specifying inlet profile INLET_FILENAME= inlet.dat % % Far-field boundary marker(s) (NONE = no marker) MARKER_FAR= ( FARIN ) % % Pressure outlet marker MARKER_OUTLET= ( FAROUT, 96305.5) % % Periodic boundary marker(s) (NONE = no marker) % Format: ( periodic marker, donor marker, rotation_center_x, rotation_center_y, % rotation_center_z, rotation_angle_x-axis, rotation_angle_y-axis, % rotation_angle_z-axis, translation_x, translation_y, translation_z, ... ) MARKER_PERIODIC= ( WALL1, WALL2,0, 0, 0, 0, 0, 0, 0, 0, -0.0254 ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( STEP, WALL1, WALL2, UPPERWALL, LOWERWALL) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( FAROUT,STEP, WALL1, WALL2, UPPERWALL, LOWERWALL,FARIN) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 0.5 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 2.0, 100.0 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % ----------------------- SLOPE LIMITER DEFINITION ----------------------------% % VENKAT_LIMITER_COEFF= 0.1 ADJ_SHARP_LIMITER_COEFF= 3.0 REF_SHARP_EDGES= 3.0 SENS_REMOVE_SHARP= NO % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % CONV_NUM_METHOD_FLOW= ROE MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN JST_SENSOR_COEFF= ( 0.5, 0.02 ) TIME_DISCRE_FLOW= EULER_IMPLICIT % % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver or smoother for implicit formulations (BCGSTAB, FGMRES, SMOOTHER_JACOBI, % SMOOTHER_ILU, SMOOTHER_LUSGS, % SMOOTHER_LINELET) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (ILU, LU_SGS, LINELET, JACOBI) % LINEAR_SOLVER_PREC= LU_SGS % % Linael solver ILU preconditioner fill-in level (0 by default) % LINEAR_SOLVER_ILU_FILL_IN= 0 % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 0.1 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 5 % % ----------------------------------- END -------------------------------------% % % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % CONV_NUM_METHOD_TURB= SCALAR_UPWIND TIME_DISCRE_TURB= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % CONV_RESIDUAL_MINVAL= -10 CONV_STARTITER= 10 CONV_CAUCHY_ELEMS= 100 CONV_CAUCHY_EPS= 1E-5 % %DV_KIND= SCALE_GRID %DV_MARKER= ( WALL1, WALL2, INLET, STEP, OUTLET, UPPERWALL, LOWERWALL ) %DV_PARAM= ( 1.0 ) %DV_VALUE = 0.01 OUTPUT_FILES= (RESTART, TECPLOT) % list of writing frequencies corresponding to the list in OUTPUT_FILES OUTPUT_WRT_FREQ= 30, 20 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= backwardstep.cgns % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= CGNS % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FILENAME= solution_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (PARAVIEW, TECPLOT, STL) TABULAR_FORMAT= TECPLOT % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_OUTPUT=(MEAN_PRESSURE, MEAN_VELOCITY-X, MEAN_VELOCITY-Y, MEAN_VELOCITY-Z, MEAN_DENSITY ,MACH) VOLUME_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % % Screen output %SCREEN_OUTPUT=(TIME_ITER, INNER_ITER, LIFT, DRAG, TOTAL_HEATFLUX) SCREEN_OUTPUT=(ITER, MAX_NU_TILDE, RMS_RES) |
June 13, 2023, 10:27 |
bigfoot
Rep Power: 21 |
Do the inner iterations converge? What is the flow supposed to do, show a turbulent vortex shedding behind the step? Do you already see some correct physics or it's still a big mess?
June 15, 2023, 06:12 |
Zhang
Rep Power: 3 |
The inner iteration has diverged, resulting in unexpected flow performance. Should I decrease the time step or increase the number of inner iterations?
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 12:54 |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 10, 2022 00:58 |
Divergence in non-Newtonian fluid UDF | moabdi | FLUENT | 0 | June 23, 2016 12:30 |
unsteady divergence simple case | hugocis | Main CFD Forum | 2 | June 10, 2010 05:24 |
Error with the unsteady flamelet Model | Christoph_84 | FLUENT | 0 | February 25, 2010 12:06 |
