The model's coordinates differ from those of the actual object. |
May 30, 2023, 23:30 |
Zhang
Rep Power: 3 |
Hi, guys.
I find the coordinates of my model is different. In the output file, it shows ------------------------------------------------------------------- Area projection in the x-plane = 0 m, y-plane = 0 m. Max. coordinate in the x-direction = -1e+10 m, y-direction = -1e+10 m. Min coordinate in the x-direction = 1e+10 m, y-direction = 1e+10 m. ------------------------------------------------------------------- But it's not my real model coordinate. I have checked my mesh, it goes well. So Why does this happen, and how can I solve it? Thanks for any help! |
June 1, 2023, 03:28 |
bigfoot
Rep Power: 21 |
It looks like for some reason SU2 is reporting the default values and does not update it with the actual values. Does your simulation run fine?
June 1, 2023, 03:39 |
Zhang
Rep Power: 3 |
The simulation results appear promising. When I set the "MARKER_MONITORING" to cover the entire model surface, the coordinates match those of my actual model.
It appears that this setting has a significant impact; should I apply it to all surfaces? |
can't find object when reconstructPar marangoni bc | wqsn123 | OpenFOAM Post-Processing | 3 | February 1, 2022 12:06 |
can I access to the "dict" object from codeWrite in a coded function object? | NotOverUnderated | OpenFOAM Programming & Development | 2 | October 28, 2021 19:46 |
[Scripting]: How to get the coordinates of a 2D airfoil @ different angles of attack? | CfdIntro | Main CFD Forum | 2 | December 12, 2017 11:23 |
Eddy Viscosity Models and Reynolds Stress Models | JuPa | CFX | 1 | August 20, 2013 19:56 |
Oriented Object Models for CFD | hurricane | Main CFD Forum | 6 | September 13, 2006 17:26 |
