May 27, 2023, 15:08 |
Blunt body symmetric simulation - MARKER_SYM
Nicola Trippella
Rep Power: 3 |
Hi
I am trying to simulate a blunt body hypersonic vehicle I would like to study only half of it. The geometry is the one attached. I divided the conical shape in the mid part. The external boundary is a semi-circonference. However, when i put in the config file the MARKER_SYM boundary condition, the launched simulation shows to me the following error message: ------------------- Geometry Preprocessing ( Zone 0 ) ------------------- Two dimensional problem. 104284 grid points before partitioning. 206975 volume elements before partitioning. 3 surface markers. 336 boundary elements in index 0 (Marker = FARFIELD). 953 boundary elements in index 1 (Marker = SYMMETRY). 189 boundary elements in index 2 (Marker = CAPSULE). Executing the partitioning functions. Building the graph adjacency structure. Calling ParMETIS... graph partitioning complete (1372 edge cuts). Distributing ParMETIS coloring. [nicola-VirtualBox:10959] *** Process received signal *** [nicola-VirtualBox:10959] Signal: Segmentation fault (11) [nicola-VirtualBox:10959] Signal code: Address not mapped (1) [nicola-VirtualBox:10959] Failing at address: 0x91 [nicola-VirtualBox:10959] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f86f479a090] [nicola-VirtualBox:10959] [ 1] SU2_CFD(+0x838360)[0x56208804c360] [nicola-VirtualBox:10959] [ 2] SU2_CFD(+0x839aac)[0x56208804daac] [nicola-VirtualBox:10959] [ 3] SU2_CFD(+0x184279)[0x562087998279] [nicola-VirtualBox:10959] [ 4] SU2_CFD(+0x1854ec)[0x5620879994ec] [nicola-VirtualBox:10959] [ 5] SU2_CFD(+0x185c0c)[0x562087999c0c] [nicola-VirtualBox:10959] [ 6] SU2_CFD(+0x18b763)[0x56208799f763] [nicola-VirtualBox:10959] [ 7] SU2_CFD(+0x12ad42)[0x56208793ed42] [nicola-VirtualBox:10959] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f86f477b083] [nicola-VirtualBox:10959] [ 9] SU2_CFD(+0x13b96e)[0x56208794f96e] [nicola-VirtualBox:10959] *** End of error message *** |
May 29, 2023, 00:18 |
Shuang Qiu
Rep Power: 5 |
I am working on a similar problem and facing the same error message. I am not sure where the problems really are but this seems to be the problem on volume definition. |
May 29, 2023, 07:05 |
#3 | |
Nicola Trippella
Rep Power: 3 |
Hi I don't know why the MARKER_SYM does not work, yet. Therefore, i decided to go on with my original complete geoemtry. I managed to reach convergence at first order just reducing the external circular domain from 80 to 50 and refining a little bit more the unstrcutred mesh, near the body. I'm reaching convergence with RMS = 10^(-7) with a first order scheme (MUSCL = NO). Now i am trying a second order scheme: MUSCL = YES SLOPE LIMITER = VENKATAKRISHNAN_WAN VENKAT_LIMITER_COEFF= 0.01 ENTROPY_FIX_COEFF= 0.1 CFL_NUMBER= 0.15 CFL_ADAPT= YES CFL_ADAPT_PARAM= (0.005, 1.005, 0.1, 1) TIME_DISCRE_FLOW= EULER_EXPLICIT However, in this case, restarting from the converged 1st order solution, su2 seems to stall at 10^(+2) or even diverges Let's keep in touch to help each other ! |
May 29, 2023, 21:24 |
Shuang Qiu
Rep Power: 5 |
How about using a structured mesh? Your case is on 2D domain and employ a block mesh strategy may works. Keep focus on post-cylinder shear layers and boundary layers. Also, allow the mesh on shock to be dense may also help. I am working on Mach 3 case and has not considered NEMO yet, haha. |
September 22, 2023, 04:15 |
#5 | |
Guangjing JU
Rep Power: 3 |
I am also facing similar divergence problem when using SU2-Nemo solver. I don't know whether the problem is the mesh or something else. Did you get convergence solution? |
boundary, marker, mesh, symmetry |
Ahmed body simulation (steady-state) | AMR96 | FLUENT | 1 | March 24, 2023 18:26 |
Reducing velocity of Ahmed body simulation. | Lewis1 | CFD Freelancers | 0 | February 8, 2017 18:40 |
How to calculate body forcefor 2d wedge impact simulation | khurrammtc | FLUENT | 0 | August 14, 2012 03:11 |
Turbulent flow over a blunt body Error Message | pradon16 | FLUENT | 0 | July 27, 2012 17:31 |
Flow around the ahmed body (large eddy simulation) | Benzamia | CFX | 0 | February 26, 2007 06:03 |
