Home > Forums > Software User Forums > SU2
Simulation beginning from initialized solution rather than restart file
Old   May 22, 2023, 13:42
Default Simulation beginning from initialized solution rather than restart file
Elliot Kimmel
eskimmel is on a distinguished road
I am trying to restart a simulation from a solution file. I am using an unsteady RK4 temporal scheme with the standard time stepping method. However, when I try to restart the simulation from a saved solution, it begins again from the freestream state. I believe I am specifying all of the correct options in my configuration file to allow the simulation to restart properly. I never had issues with this when using the dual time stepping method, but I am with standard time stepping. The output file also says it is reading the previous solution state correctly.
I am attaching my configuration file and two pictures showing the solution used for the restart and the solution that results one time step after the restart. Any help would be appreciated. Thanks!
File Type: txt flatplate_M2p9_short_wr_dt1neg8_ROE_original_2ndOrder_withMUSCL_isothermal_withlimiter.txt (7.7 KB, 8 views)
eskimmel is offline   Reply With Quote
Old   May 30, 2023, 18:39
bigfoot
bigfootedrockmidget is on a distinguished road
Did you manage to solve this problem? If not, could you confirm that the restart file actually contains the correct solution by inspecting the csv file (it might be different from the visualization files)? Could you then also confirm that the correct file is used for the restart?
bigfootedrockmidget is offline   Reply With Quote
Old   June 19, 2023, 11:03
Elliot Kimmel
No, I have not been able to solve this problem. I checked the .csv and confirmed that the correct solution is actually contained within it. I am restarting from iteration number 500000. In the output file, it says that the flow solution is being read from solution.csv, not solution_499999.csv, though I do not think this is an issue since it is simply repeating information from the .cfg file (plus, solution.csv doesn't even exist).
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
