May 17, 2023, 05:10 |
Error in Physical Surface Marker
Nicola Trippella
Rep Power: 3 |
Hi
I'm trying to run a simulation of an apollo-like capsule I have the farfield that is a circle Inside i have a conical shape 2D In the geo file i have defined the markers as follows: // capsule Curve Loop(1) = {4,1,3,2,5,6,7,8}; // farfield Curve Loop(2) = {9}; Plane Surface(1) = {1,2}; Physical Curve("FARFIELD")= {9}; Physical Curve("CAPSULE")= {4,1,3,2,5,6,7,8}; Physical Surface("VOLUME") = {1}; Obv, in my config i am placing BC markers on the capsule and on the farfield, while the Physcial Surface called "VOLUME" does not require any BC , any marker: MARKER_EULER= ( CAPSULE ) MARKER_FAR= ( FARFIELD ) MARKER_PLOTTING= ( NONE ) MARKER_MONITORING= ( CAPSULE ) However, the simulation does not beging , showing me this error: Error in "short unsigned int CConfig::GetMarker_CfgFile_TagBound(std::string) const": ------------------------------------------------------------------------- The configuration file doesn't have any definition for marker VOLUME ------------------------------ Error Exit ------------------------------- I tried to set the number of marker as 2 in the geo file (NMARK = 2) But the result is the same Help me please! |
May 17, 2023, 05:30 |
bigfoot
Rep Power: 18 |
The physical volume should not be present in the SU2 file. If you are using gmsh 4.11.* then use an older version, there is a bug in gmsh for this version.
May 17, 2023, 05:33 |
Nicola Trippella
Rep Power: 3 |
Thank you so much for your prompt reply.
Which version i have to install? How can i do it easily? |
May 17, 2023, 06:09 |
yassss
Nicola Trippella
Rep Power: 3 |
thank you , i have installed gmsh 4.10.5
Very kind and helpful sorry and thanks <3 |
May 17, 2023, 07:01 |
New error
Nicola Trippella
Rep Power: 3 |
I had now another error, uff :
Mismatch between NPOIN and number of points listed in mesh file. Please check the mesh file for correctness. I have created the geoemtry with CAD, impprted as a step file I don't knwo how to fix this problem |
config, gmsh, markers, physical groups, volume |
[Gmsh] Physical Surfaces not becoming patches - gmshToFoam | turinturambar | OpenFOAM Meshing & Mesh Conversion | 7 | November 16, 2021 10:07 |
sHM doesn't add layers to any surface | Vinzmann | Mesh Generation & Pre-Processing | 0 | March 23, 2021 05:02 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
FREE SURFACE TRACING USING MARKER PARTICLES!!??? | lost_soul | Main CFD Forum | 2 | April 7, 2000 00:35 |
