May 4, 2023, 06:01 |
Multiple surfaces outputs
Rep Power: 5 |
Hi everyone,
I am running a case using SU2 7.1.1 . I am trying to write one surface file per marker labelled as wall. I have seen in previous posts that I have to run multiple SU2_SOL cases to be able to write these outputs while modifying the MARKER_MONITORING variable to match the extract I need. However, each time I run the SU2_SOL to produce this surface file, it also writes the Volume file. Is there a solution to deactivate the writing of the volume? Because in the end it takes a lot of time... Thank you in advance |
May 5, 2023, 00:39 |
Pedro Gomes
Rep Power: 14 |
See volume_output in this page https://su2code.github.io/docs_v7/Custom-Output/
[snappyHexMesh] SHM doesn't snap the boundary between two surfaces on same plane | decanter | OpenFOAM Meshing & Mesh Conversion | 4 | November 17, 2020 16:32 |
Surfaces output for two regions. | Jan995 | OpenFOAM Post-Processing | 1 | October 31, 2020 15:31 |
Specifying points for sampling surfaces in sampleDict | arieljeds | OpenFOAM Post-Processing | 0 | April 20, 2016 08:11 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 02:56 |
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat | CFD XUE | FLUENT | 3 | March 18, 2015 04:28 |
