Home > Forums > Software User Forums > SU2
uable to run a multiphysics config file
Old   May 3, 2023, 22:10
Default uable to run a multiphysics config file
samaneh
SamanehJ is on a distinguished road
Hi everyone,
I am trying to run a multiphysics configuration file, but I am not sure why it stops on the first line, while it runs perfectly on my friend's system.
I receive this error:Error in "void CConfig::SetConfig_Parsing(std::istream&)":
is it possible it's because of the version of the SU2 that I am working with?
mine's version is 7.3.1 while my friend's is 7.5
if so, what is the command line for the update on Linux?
SamanehJ is offline   Reply With Quote
Old   May 4, 2023, 21:45
pcg
Pedro Gomes
pcg is on a distinguished road
What else is printed? Does it mention any option?
pcg is offline   Reply With Quote
Old   May 5, 2023, 08:07
bigfoot
bigfootedrockmidget is on a distinguished road
Can you specify what "it" is? Are you moving (ascii) files between windows and linux? If so, please check if this introduced changes to the file.
bigfootedrockmidget is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
