April 20, 2023, 16:25 |
SU2 incompressible laminar flow
I'm working on a problem, where I need to simulate the laminar base flow around an object on a flat plate. In order to reduce computational time, I prescribe the already developed Blasius-profile at the inlet. The rest of the boundary conditions are symmetries on the sides, 0 pressure outlets on the top and end of the domain, and no-slip walls at the object and the flat plate. This worked while using CFX, but I would like to migrate the process to SU2, to avoid license issues on HPCs. As such, I tried creating a simple problem to test my .cfg file, which I based on the laminar backwards-facing step example. This simple problem is a cube (without the roughness element inside), with the same BCs as listed above. But I ran into some problems, for which I would like to ask for some help. The first problem is, that although I prescribe symmetry markers at the sides, the velocity has a small z component, which should be zero, as it is normal to the symmetry plane. This can be seen on the picture named vel_z, the other side has the same velocity magnitude with opposite signs. The second problem is, the pressure field seems to behave in a wierd way as well. For example on the outlets, non-zero pressure can be observed (outlet_p.png). I tried plotting the imported inlet profiles, and found that a small amount of z component gets added to the inlet, even though my profile does not contain z components. The other two component, (x, y) are imported as intended. My guess is, that the prescribed boundary conditions seem to effect each other in a negative way, causing these anomalies, but have no idea how to fix it. My .cfg file: Code:
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % % SU2 configuration file % % Case description: _________________________________________________________ % % Author: ___________________________________________________________________ % % Institution: ______________________________________________________________ % % Date: __________ % % File Version 7.5.1 "Blackbird" % % % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Solver type (EULER, NAVIER_STOKES, RANS, % INC_EULER, INC_NAVIER_STOKES, INC_RANS, % NEMO_EULER, NEMO_NAVIER_STOKES, % FEM_EULER, FEM_NAVIER_STOKES, FEM_RANS, FEM_LES, % HEAT_EQUATION_FVM, ELASTICITY) SOLVER= INC_NAVIER_STOKES % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT, DISCRETE_ADJOINT) % Defaults to DISCRETE_ADJOINT for the SU2_*_AD codes, and to DIRECT otherwise. MATH_PROBLEM= DIRECT % Restart solution (NO, YES) RESTART_SOL= NO % % System of measurements (SI, US) % International system of units (SI): ( meters, kilograms, Kelvins, % Newtons = kg m/s^2, Pascals = N/m^2, % Density = kg/m^3, Speed = m/s, % Equiv. Area = m^2 ) % United States customary units (US): ( inches, slug, Rankines, lbf = slug ft/s^2, % psf = lbf/ft^2, Density = slug/ft^3, % Speed = ft/s, Equiv. Area = ft^2 ) SYSTEM_MEASUREMENTS= SI % % ------------------------------- SOLVER CONTROL ------------------------------% % % Number of iterations for single-zone problems ITER= 1 % % Maximum number of inner iterations INNER_ITER= 9999 % % Convergence field CONV_FIELD= RMS_PRESSURE, RMS_VELOCITY-X, RMS_VELOCITY-Y, RMS_VELOCITY-Z % % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -12 % % Start convergence criteria at iteration number CONV_STARTITER= 10 % % Number of elements to apply the criteria CONV_CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CONV_CAUCHY_EPS= 1E-10 % % ---------------- INCOMPRESSIBLE FLOW CONDITION DEFINITION -------------------% % % Density model within the incompressible flow solver. % Options are CONSTANT (default), BOUSSINESQ, or VARIABLE. If VARIABLE, % an appropriate fluid model must be selected. INC_DENSITY_MODEL= CONSTANT % % Initial density for incompressible flows % (1.2886 kg/m^3 by default (air), 998.2 Kg/m^3 (water)) INC_DENSITY_INIT= 1.225 % % Initial velocity for incompressible flows (1.0,0,0 m/s by default) INC_VELOCITY_INIT= ( 6.0, 0.0174, 0.0 ) % % List of inlet types for incompressible flows. List length must % match number of inlet markers. Options: VELOCITY_INLET, PRESSURE_INLET. INC_INLET_TYPE= VELOCITY_INLET % % Damping coefficient for iterative updates at pressure inlets. (0.1 by default) INC_INLET_DAMPING= 0.1 % % Non-dimensionalization scheme for incompressible flows. Options are % INITIAL_VALUES (default), REFERENCE_VALUES, or DIMENSIONAL. % INC_*_REF values are ignored unless REFERENCE_VALUES is chosen. INC_NONDIM= DIMENSIONAL % % List of outlet types for incompressible flows. List length must % match number of outlet markers. Options: PRESSURE_OUTLET, MASS_FLOW_OUTLET INC_OUTLET_TYPE= PRESSURE_OUTLET, PRESSURE_OUTLET % % Damping coefficient for iterative updates at mass flow outlets. (0.1 by default) INC_OUTLET_DAMPING= 0.1 % % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY, POLYNOMIAL_VISCOSITY). VISCOSITY_MODEL= CONSTANT_VISCOSITY % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 0.00001789357 % % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Symmetry boundary marker(s) (NONE = no marker) % Implementation identical to MARKER_EULER. %MVG két olalán MARKER_SYM= ( sym_l, sym_r ) % % Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker) % Format: ( marker name, constant heat flux (J/m^2), ... ) MARKER_HEATFLUX= ( wall, 0.0 ) % % Internal boundary marker(s) e.g. no boundary condition (NONE = no marker) %MARKER_INTERNAL= ( NONE ) % % Inlet boundary type (TOTAL_CONDITIONS, MASS_FLOW) %INLET_TYPE= TOTAL_CONDITIONS % % Read inlet profile from a file (YES, NO) default: NO SPECIFIED_INLET_PROFILE= YES % % File specifying inlet profile INLET_FILENAME= blasius_prof.dat % % Inlet boundary marker(s) with the following formats (NONE = no marker) % Total Conditions: (inlet marker, total temp, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Mass Flow: (inlet marker, density, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Inc. Velocity: (inlet marker, temperature, velocity magnitude, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. % Inc. Pressure: (inlet marker, temperature, total pressure, flow_direction_x, % flow_direction_y, flow_direction_z, ... ) where flow_direction is % a unit vector. MARKER_INLET= ( inlet, 1.0, 1.0, 1.0, 1.0, 0.0 ) % % Outlet boundary marker(s) (NONE = no marker) % Compressible: ( outlet marker, back pressure (static thermodynamic), ... ) % Inc. Pressure: ( outlet marker, back pressure (static gauge in Pa), ... ) % Inc. Mass Flow: ( outlet marker, mass flow target (kg/s), ... ) MARKER_OUTLET= ( outlet_end, 0.0, outlet_top, 0.0 ) % % ------------------------ SURFACES IDENTIFICATION ----------------------------% % % Marker(s) of the surface in the surface flow solution file, %IT can be exported to csv files MARKER_PLOTTING = ( outlet_end ) % % Marker(s) of the surface where the non-dimensional coefficients are evaluated. MARKER_MONITORING = ( wall ) % % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS % % CFL number (initial value for the adaptive CFL number) CFL_NUMBER= 15.0 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor-down, factor-up, CFL min value, CFL max value, acceptable linear solver convergence) % Local CFL increases by factor-up until max if the solution rate of change is not limited, % and acceptable linear convergence is achieved. It is reduced if rate is limited, or if there % is not enough linear convergence, or if the nonlinear residuals are stagnant and oscillatory. % It is reset back to min when linear solvers diverge, or if nonlinear residuals increase too much. CFL_ADAPT_PARAM= ( 1.5, 0.5, 25.0, 10000.0 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % ----------------------- SLOPE LIMITER DEFINITION ----------------------------% % % Coefficient for the limiter VENKAT_LIMITER_COEFF= 0.05 % % Coefficient for the sharp edges limiter ADJ_SHARP_LIMITER_COEFF= 3.0 % % Reference coefficient (sensitivity) for detecting sharp edges. REF_SHARP_EDGES= 3.0 % % Remove sharp edges from the sensitivity evaluation (NO, YES) SENS_REMOVE_SHARP= NO % % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver for implicit formulations (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (JACOBI, LINELET, LU_SGS) LINEAR_SOLVER_PREC= ILU % % Linael solver ILU preconditioner fill-in level (0 by default) LINEAR_SOLVER_ILU_FILL_IN= 0 % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-15 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 20 % % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= FDS % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= YES % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_FLOW= NONE % % 2nd and 4th order artificial dissipation coefficients JST_SENSOR_COEFF= ( 0.0, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % % ------------------------- INPUT/OUTPUT FILE INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= test_mesh.su2 % % Mesh input file format (SU2, CGNS) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FILENAME= solution_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output tabular file format (TECPLOT, CSV) TABULAR_FORMAT= CSV % % Files to output % Possible formats : (TECPLOT_ASCII, TECPLOT, SURFACE_TECPLOT_ASCII, % SURFACE_TECPLOT, CSV, SURFACE_CSV, PARAVIEW_ASCII, PARAVIEW_LEGACY, SURFACE_PARAVIEW_ASCII, % SURFACE_PARAVIEW_LEGACY, PARAVIEW, SURFACE_PARAVIEW, RESTART_ASCII, RESTART, CGNS, SURFACE_CGNS, STL_ASCII, STL_BINARY) % default : (RESTART, PARAVIEW, SURFACE_PARAVIEW) OUTPUT_FILES= (RESTART, PARAVIEW, CSV, SURFACE_CSV SURFACE_PARAVIEW) % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % ------------------------- SCREEN/HISTORY VOLUME OUTPUT --------------------------% % % Screen output fields (use 'SU2_CFD -d <config_file>' to view list of available fields) SCREEN_OUTPUT= (INNER_ITER, RMS_PRESSURE, RMS_VELOCITY-X, RMS_VELOCITY-Y, RMS_VELOCITY-Z) % % History output groups (use 'SU2_CFD -d <config_file>' to view list of available fields) HISTORY_OUTPUT= (ITER, RMS_RES) % % Volume output fields/groups (use 'SU2_CFD -d <config_file>' to view list of available fields) VOLUME_OUTPUT= (COORDINATES, SOLUTION) % % Writing frequency for screen output SCREEN_WRT_FREQ_INNER= 1 % SCREEN_WRT_FREQ_OUTER= 1 % SCREEN_WRT_FREQ_TIME= 1 % % Writing frequency for history output HISTORY_WRT_FREQ_INNER= 1 % HISTORY_WRT_FREQ_OUTER= 1 % HISTORY_WRT_FREQ_TIME= 1 % % list of writing frequencies corresponding to the list in OUTPUT_FILES OUTPUT_WRT_FREQ= 75, 75, 75 % % Output the performance summary to the console at the end of SU2_CFD WRT_PERFORMANCE= YES % % Overwrite or append iteration number to the restart files when saving WRT_RESTART_OVERWRITE= YES % % Overwrite or append iteration number to the surface files when saving WRT_SURFACE_OVERWRITE= YES % % Overwrite or append iteration number to the volume files when saving WRT_VOLUME_OVERWRITE= YES blasius_prof.dat test_mesh.su2 Any help would be appriciated. Thanks in advance! |
April 24, 2023, 06:34 |
bigfoot
Rep Power: 21 |
It is difficult to get a symmetry plane to act as a perfect mirror. What you see here is probably a limitation of the current implementation of the symmetry plane in the case that a single cell shares a symmetry, an inlet and a wall (the corner cell).
You might see some improvement when you make the cells lying on the wall smaller in the direction normal to the wall. |
April 25, 2023, 13:12 |
#3 | |
April 30, 2023, 23:59 |
Pedro Gomes
Rep Power: 14 |
You can try using translational periodicity instead of symmetry along the sides.
Having a part of the bottom wall as an inviscid wall should also help (so that the inlet doesn't hit the plate directly). |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 06:21 |
High velocity in Laminar flow | Manojmech | FLUENT | 0 | November 3, 2016 05:37 |
Incompressible laminar poiseuille flow | samarth | OpenFOAM Running, Solving & CFD | 20 | July 13, 2010 04:38 |
