Home > Forums > Software User Forums > SU2
The simulation has diverged
Old   April 20, 2023, 03:43
Default The simulation has diverged
Zhang
Amber0922 is on a distinguished road
I try to run the backward step model, but comes to some questions. When I try to run my config file, it shows
Error in "void CSolver::SetResidual_RMS(const CGeometry*, const CConfig*)":
SU2 has diverged (NaN detected).
I think maybe I forget to set something, but I don't find it. Here is my config file.
% Physical governing equations (EULER, NAVIER_STOKES,
% WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,
% POISSON_EQUATION)
SOLVER= RANS
KIND_TURB_MODEL= SA
HYBRID_RANSLES= SA_EDDES
% Mathematical problem (DIRECT, CONTINUOUS_ADJOINT)
MATH_PROBLEM= DIRECT
% Axisymmetric simulation, only compressible flows (NO, YES)
AXISYMMETRIC= NO
% Restart solution (NO, YES)
RESTART_SOL= NO
SYSTEM_MEASUREMENTS= SI
% ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------%
MACH_NUMBER= 0.128
AOA= 0.0
SIDESLIP_ANGLE= 0.0
FREESTREAM_TEMPERATURE= 298.3
FREESTREAM_VELOCITY= ( 44.2, 0.00, 0.00 )
REYNOLDS_NUMBER= 36000
REYNOLDS_LENGTH= 1.0
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
% Reference origin for moment computation
REF_ORIGIN_MOMENT_X = 0.25
REF_ORIGIN_MOMENT_Y = 0.00
REF_ORIGIN_MOMENT_Z = 0.00
% Reference length for pitching, rolling, and yawing non-dimensional moment
REF_LENGTH= 1.0
% Reference area for force coefficients (0 implies automatic calculation)
REF_AREA= 0
% ------------------------- UNSTEADY SIMULATION -------------------------------%
TIME_DOMAIN= YES
TIME_MARCHING= DUAL_TIME_STEPPING-2ND_ORDER
% U_inf = 69.4448 - dt*=0.02 - dt=0.000288
TIME_STEP= 0.00046
MAX_TIME= 0.689
UNST_CFL_NUMBER= 0.0
INNER_ITER= 80
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
MARKER_HEATFLUX= ( STEP, 0.0, UPPERWALL,0.0, LOWERWALL,0.0 )
flow_direction_x,
MARKER_INLET= ( INLET, 298.3, 44.2, 1.0, 0.0, 0.0 )
MARKER_SYM= ( WALL1, WALL2 )
MARKER_OUTLET= ( OUTLET, 0.0 )
MARKER_PLOTTING= ( STEP, WALL1, WALL2, UPPERWALL, LOWERWALL)
MARKER_MONITORING= ( STEP, WALL1, WALL2, UPPERWALL, LOWERWALL )
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
NUM_METHOD_GRAD= GREEN_GAUSS
CFL_NUMBER= 10.0
CFL_ADAPT= NO
CFL_ADAPT_PARAM= ( 1.5, 0.5, 2.0, 100.0 )
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
TIME_ITER= 2000
% ----------------------- SLOPE LIMITER DEFINITION ----------------------------%
MUSCL_FLOW= YES
SLOPE_LIMITER_FLOW= NONE
MUSCL_TURB= NO
VENKAT_LIMITER_COEFF= 0.05
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
CONV_NUM_METHOD_FLOW= SLAU2
TIME_DISCRE_FLOW= EULER_IMPLICIT
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
TIME_DISCRE_TURB= EULER_IMPLICIT
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
CONV_RESIDUAL_MINVAL= -15
CONV_STARTITER= 10
CONV_CAUCHY_ELEMS= 100
CONV_CAUCHY_EPS= 1E-6
MESH_FILENAME= backwardstep.cgns
MESH_FORMAT= CGNS
MESH_OUT_FILENAME= mesh_out.su2
SOLUTION_FILENAME= solution_flow.dat
SOLUTION_ADJ_FILENAME= solution_adj.dat
TABULAR_FORMAT= TECPLOT
CONV_FILENAME= history
RESTART_FILENAME= restart_flow.dat
RESTART_ADJ_FILENAME= restart_adj.dat
VOLUME_FILENAME= flow
VOLUME_ADJ_FILENAME= adjoint
SURFACE_FILENAME= surface_flow
SURFACE_ADJ_FILENAME= surface_adjoint
SCREEN_OUTPUT=(TIME_ITER, INNER_ITER, LIFT, DRAG, TOTAL_HEATFLUX)
Amber0922 is offline   Reply With Quote
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Simulation fails after adding multi-component gas ConorH STAR-CCM+ 3 January 20, 2017 10:50
setting up a simulation with multiple interactions phandy OpenFOAM Running, Solving & CFD 1 October 6, 2014 04:16
