Home > Forums > Software User Forums > SU2
Boundary conditions for Hovering Rotor
Old   March 12, 2023, 17:15
Default Boundary conditions for Hovering Rotor
Kamran
Kamranh01 is on a distinguished road
Hi guys I managed to finally get my simulation to run with the euler solver
I wanted to ask about the boundary conditions I have set up. My study is basically analyzing the performance of a rotor system of a medium-scale UAV in SU2 using periodic boundary conditions at different altitudes on Earth. The Rotor is simplified by being in hover conditions, meaning no forward flight modeling is necessary. The rotor is just the 3D aerofoil submerged within a section of cylindrical farfield.
1) if the rotor is in hover, does that mean the freestream mach must be equal to zero since the rotor is taken at hover?
2) My boundary conditions in SU2 are as follows
Pressure inlet- set to 101325Pa (atmospheric pressure) with zero directional unit vector as its still air
Pressure Outlet- set to 101325Pa (atmospheric pressure)
Periodic markers at the two sides
Far-field marker for the edge of the cylinder
is this correct? or should the inlet and outlet have different pressures? If so how would I go about calculating the pressure at the outlet?
I think that is all for now
Kamranh01 is offline   Reply With Quote
Old   November 14, 2023, 06:02
Bakhshi Mehul
Bakhshi is on a distinguished road
Hello
Hope you are doing well
I wanted to know if you were able to figure out correct boundary conditions for hovering rotor. I am currently trying to simulate a similar rotor hover problem and facing some convergence issue.
Thank for the help.
Bakhshi is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
