Home > Forums > Software User Forums > SU2
CFL Number for Incompressible RANS
Old   February 6, 2023, 12:34
Default CFL Number for Incompressible RANS
Robert
decenu is on a distinguished road
Hi all,
I am working on relatively simple simulations using the Incompressible RANS solver paired with SST turbulence modelling.
I am trying to understand how the CFL number setting affects the results. Whilst I understand that the physical phenomenon should be steady state, SU2 runs a pseudo time iteration.
My questions are:
1. Can the CFL number cause divergence of a solution?
2. Can the CFL number directly affect the solution (convergence, accuracy and result)?
3. How does the adaptive CFL number change?
4. Any good practices for setting the CFL number?
It would be greatly appreciated if anyone could help out with these, in order to decrease my fear of solution variation/error/uncertainty in my calculations.
Thank you in advance!
decenu is offline   Reply With Quote
Old   February 6, 2023, 15:13
bigfoot
bigfootedrockmidget is on a distinguished road
Yes. For steady state problems, you use a pseudo-transient approach in SU2. You are solving a time-dependent problem but SU2 uses a timestep that is large and can be different in every cell. The CFL number is a scaling of the (local) timestep computed by SU2. If it is too large, you get divergence.
If the problem has only 1 solution for your initial and boundary conditions, then you have found the numerical approximation of this solution when the solver converges, this is independent of the CFL.
You can read the description of all configuration options in the config_template.cfg
SU2 will compute a large, but safe value of the time step. If SU2 did a 'perfect' job, then the CFL (for your incompressible steady problem) should be 1.0. If you have no clue, then start with 1.
bigfootedrockmidget is offline   Reply With Quote
cfl, inc_rans, steady, su2
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
use the message in macro DEFINE_PROFILE with parallel processor alireza_T Fluent UDF and Scheme Programming 3 May 11, 2022 03:08
CFL Number in CFX RANS AS_Aero CFX 6 April 2, 2019 04:04
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
