Home > Forums > Software User Forums > SU2
How to tetrahedron from a triangular mesh?
Old   January 16, 2023, 03:46
Default How to tetrahedron from a triangular mesh?
zhangqiang
zhang-qiang is on a distinguished road
For example, I have a triangular mesh for 3D volume object. In order to generate `SU2` file, I need to firstly generate triangular mesh.
Is there any powerful python package to generate tetrahedron from a triangular mesh? Any suggestion is appreciated~~~
zhang-qiang is offline   Reply With Quote
Old   January 16, 2023, 06:46
bigfoot
bigfootedrockmidget is on a distinguished road
I suggest you try to do everything in gmsh using structured meshes.
The best thing imo that you could do is to build the 3D model from scratch from your own geometry definition. If you have some kind of irregular geometric shape already, then convert the edges of the shape to a collection of lines and load that in gmsh.If you have the mathematical definition of the shape, then use that to define the edges. For instance, you can define a circular face in gmsh and then extrude that face according to some user defined expression. See for instance the gmsh .geo file of this tutorial:
https://su2code.github.io/tutorials/...pendent_Model/
or this gmsh video: https://www.youtube.com/watch?v=VokUbWUhU-c
and the gmsh manual, specifically 2.19
https://gmsh.info/doc/texinfo/gmsh.html
I hope this helps.
bigfootedrockmidget is offline   Reply With Quote
Old   January 16, 2023, 23:10
zhangqiang
Many thanks. I will try gmsh~~~
tetrahedron
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
GeometricField -> mesh() Function Tobi OpenFOAM Programming & Development 10 November 19, 2020 12:33
Non-physcial solution in the case of triangular mesh from interFoam ata OpenFOAM 28 September 4, 2016 12:59
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
