No Momentum_X,Y,Z data provided in the surface_flow.vtu? |
January 12, 2023, 07:37 |
Rep Power: 4 |
Hey, I run a 3D case in the Testcases/rans/oneram6. When it produces the surface_flow.vtu, I open it by Tecplot. However, I find that the values of Momentum_X,Y,Z are all equal to zero. I am a new CFDer. I am wondering how to output the exact Momentum_X,Y,Z on the surface?
January 12, 2023, 08:32 |
bigfoot
Rep Power: 21 |
The surface_flow.vtu contains only the wing surface (the surface defined with MARKER_PLOTTING), and the velocity is zero on the surface. Try the flow.vtu file instead.
If you want to have the information on boundaries and the interior as separate entities, then save as PARAVIEW_MULTIBLOCK instead and view the .vtm file in paraview. |
January 12, 2023, 09:26 |
Rep Power: 4 |
Thank you for your quick reply. I ignored the effects of boundary conditions.
In fact, I want to visualize the surface flow by extracting surface streamlines from velocity/momentum. It seems unavailable in my original practice with zero surface momentum. Do you have any sugguestions for extracting surface streamlines? |
January 12, 2023, 14:48 |
bigfoot
Rep Power: 21 |
Are we both talking about the same thing, the surface of the wing? The flow velocity on a solid no-slip surface is zero, so you cannot define a streamline on the surface. Do you have a picture of what you would like to achieve?
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 03:47 |
[OpenFOAM] saving data in paraview | aylalisa | ParaView | 3 | May 31, 2014 12:38 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
