Anders Aamodt Resell
Rep Power: 4 ![]() |
I have tried becoming familiar with SU2 lately, but I am struggling a lot to get convergent results in general.
I tried setting up a very simple 2D cylinder flow case, and I would be happy to get some input as to why it's not converging. If I'm unable to run simple case like this successfully don't see how I will be ever able to run more complicated cases ![]() The triangular mesh is generated in salome, and converted to .su2 format with a python script. With the current settings, density rms reached a minimum value of about -1.5. Navier stokes equations are being solved and farfield boundaries are used. I added a picture of the mesh and the mesh quality statistics. Config options are pasted below: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Autogenerated config file %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Physical governing equations (EULER, NAVIER_STOKES,WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,POISSON_EQUATION) SOLVER= NAVIER_STOKES KIND_TURB_MODEL= NONE MATH_PROBLEM= DIRECT RESTART_SOL= NO % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION -------------------- MACH_NUMBER= 2 AOA= 0.0 SIDESLIP_ANGLE= 0.0 INIT_OPTION= TD_CONDITIONS FREESTREAM_OPTION= TEMPERATURE_FS FREESTREAM_TEMPERATURE= 288.15 FREESTREAM_PRESSURE= 101325.0 % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS ------- FLUID_MODEL= STANDARD_AIR % --------------------------- VISCOSITY MODEL --------------------------------- VISCOSITY_MODEL= SUTHERLAND % --------------------------- THERMAL CONDUCTIVITY MODEL ---------------------- CONDUCTIVITY_MODEL= CONSTANT_PRANDTL % ---------------------- REFERENCE VALUE DEFINITION --------------------------- REF_ORIGIN_MOMENT_X= 0.25 REF_ORIGIN_MOMENT_Y= 0.0 REF_ORIGIN_MOMENT_Z= 0.0 REF_LENGTH= 1.0 REF_AREA= 1.0 REF_DIMENSIONALIZATION= DIMENSIONAL % -------------------- BOUNDARY CONDITION DEFINITION -------------------------- MARKER_HEATFLUX= (projectile,0.0) MARKER_EULER= NONE MARKER_FAR= (farfield,outlet) INLET_TYPE= MASS_FLOW MARKER_INLET= NONE MARKER_OUTLET= NONE MARKER_SUPERSONIC_INLET= NONE MARKER_SUPERSONIC_OUTLET= NONE MARKER_SYM= NONE MARKER_PLOTTING= projectile MARKER_MONITORING= projectile % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD --------------- NUM_METHOD_GRAD= GREEN_GAUSS CFL_NUMBER= 20 CFL_ADAPT= NO INNER_ITER= 1000 % ------------------------ LINEAR SOLVER DEFINITION --------------------------- LINEAR_SOLVER= FGMRES LINEAR_SOLVER_PREC= ILU LINEAR_SOLVER_ERROR= 1e-10 LINEAR_SOLVER_ITER= 10 % -------------------------- MULTIGRID PARAMETERS ----------------------------- MGLEVEL= 0 % -------------------- FLOW NUMERICAL METHOD DEFINITION ----------------------- CONV_NUM_METHOD_FLOW= ROE ENTROPY_FIX_COEFF= 0.01 JST_SENSOR_COEFF= ( 0.5, 0.02 ) MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN VENKAT_LIMITER_COEFF= 0.05 TIME_DISCRE_FLOW= EULER_IMPLICIT USE_ACCURATE_FLUX_JACOBIANS= YES % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------ CONV_NUM_METHOD_TURB= SCALAR_UPWIND MUSCL_TURB= NO SLOPE_LIMITER_TURB= VENKATAKRISHNAN TIME_DISCRE_TURB= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS -------------------------- CONV_FIELD= RMS_DENSITY CONV_RESIDUAL_MINVAL= -5 CONV_STARTITER= 10 % ------------------------- INPUT/OUTPUT INFORMATION -------------------------- MESH_FILENAME= /home/anders/dev/CFD-Traject/Tests/2Dcylinder/2Dcyl.su2 MESH_FORMAT= SU2 MESH_OUT_FILENAME= /home/anders/dev/CFD-Traject/Tests/2Dcylinder/configuration_0/flow_output/mesh_out.su2 SOLUTION_FILENAME= solution_flow.dat TABULAR_FORMAT= CSV CONV_FILENAME= /home/anders/dev/CFD-Traject/Tests/2Dcylinder/configuration_0/flow_output/history RESTART_FILENAME= /home/anders/dev/CFD-Traject/Tests/2Dcylinder/configuration_0/flow_output/restart_flow.dat VOLUME_FILENAME= /home/anders/dev/CFD-Traject/Tests/2Dcylinder/configuration_0/flow_output/flow SURFACE_FILENAME= /home/anders/dev/CFD-Traject/Tests/2Dcylinder/configuration_0/flow_output/surface_flow SCREEN_OUTPUT= ( INNER_ITER, WALL_TIME, REL_RMS_DENSITY, RMS_DENSITY, LIFT, DRAG ) HISTORY_OUTPUT= ( INNER_ITER, REL_RMS_DENSITY, RMS_DENSITY, LIFT, DRAG ) |
Pedro Gomes
Rep Power: 13 ![]() |
What is the diameter? Is this supposed to be laminar? And if so, is it supposed to be steady state?
The diameter is 1m, but the point was not really to try and model viscous effects. I was looking for a steady solution. I changed the solver to EULER to simplify things and eliminate the potential for vortex shredding, but still, the solution doesn't converge. It stops converging at density rms = -0.35.
Pedro Gomes
Inviscid flow is not potential flow, it will still separate and become unsteady, just in an unphysical way.
If you want any steady solution around a cylinder you need conditions and models that give you steady state. |
Ahh, that was clarifying to hear, thanks! I tried the pseudo time stepping of 1st order and it gave me good convergence for the navier stokes equations, however the Euler equations still flatline at density rms = -0.75. Not really sure what I can do to make the latter case work though. Anyhow I will probably use the time domain stepping as my default setup from now since it seems more robust, but please correct me if that's a dumb idea.
Here is my cfg file for the Euler problem as reference: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Autogenerated config file %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Physical governing equations (EULER, NAVIER_STOKES,WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,POISSON_EQUATION) SOLVER= EULER KIND_TURB_MODEL= SA MATH_PROBLEM= DIRECT RESTART_SOL= NO % ------------------------- UNSTEADY SIMULATION ------------------------------- TIME_DOMAIN= YES TIME_MARCHING= DUAL_TIME_STEPPING-1ST_ORDER UNST_CFL_NUMBER= 3000 TIME_STEP= 0 MAX_TIME= 1 TIME_ITER= 1000 % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION -------------------- MACH_NUMBER= 2 AOA= 0.0 SIDESLIP_ANGLE= 0.0 INIT_OPTION= TD_CONDITIONS FREESTREAM_OPTION= TEMPERATURE_FS FREESTREAM_TEMPERATURE= 288.15 FREESTREAM_PRESSURE= 101325.0 % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS ------- FLUID_MODEL= STANDARD_AIR % --------------------------- VISCOSITY MODEL --------------------------------- VISCOSITY_MODEL= SUTHERLAND % --------------------------- THERMAL CONDUCTIVITY MODEL ---------------------- CONDUCTIVITY_MODEL= CONSTANT_PRANDTL % ---------------------- REFERENCE VALUE DEFINITION --------------------------- REF_ORIGIN_MOMENT_X= 0.25 REF_ORIGIN_MOMENT_Y= 0.0 REF_ORIGIN_MOMENT_Z= 0.0 REF_LENGTH= 1.0 REF_AREA= 1.0 REF_DIMENSIONALIZATION= DIMENSIONAL % -------------------- BOUNDARY CONDITION DEFINITION -------------------------- MARKER_HEATFLUX= ( NONE, 0.0 ) MARKER_EULER= projectile MARKER_FAR= (farfield,outlet) MARKER_PLOTTING= projectile MARKER_MONITORING= projectile % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD --------------- NUM_METHOD_GRAD= GREEN_GAUSS CFL_NUMBER= 40 CFL_ADAPT= YES CFL_ADAPT_PARAM= ( 0.1, 2.0, 1.0, 10000000000.0 ) INNER_ITER= 7 % ------------------------ LINEAR SOLVER DEFINITION --------------------------- LINEAR_SOLVER= FGMRES LINEAR_SOLVER_PREC= LU_SGS LINEAR_SOLVER_ERROR= 0.0001 LINEAR_SOLVER_ITER= 7 % -------------------------- MULTIGRID PARAMETERS ----------------------------- MGLEVEL= 0 % -------------------- FLOW NUMERICAL METHOD DEFINITION ----------------------- CONV_NUM_METHOD_FLOW= ROE ENTROPY_FIX_COEFF= 0.01 JST_SENSOR_COEFF= ( 0.5, 0.02 ) MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN VENKAT_LIMITER_COEFF= 0.05 TIME_DISCRE_FLOW= EULER_IMPLICIT USE_ACCURATE_FLUX_JACOBIANS= YES % --------------------------- CONVERGENCE PARAMETERS -------------------------- CONV_FIELD= REL_RMS_DENSITY CONV_RESIDUAL_MINVAL= -3 CONV_STARTITER= 10 |
Low Mach number wing/body junction convergence | Zen | SU2 | 6 | May 3, 2019 04:51 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 18:17 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
