version7.5.0 Downloaded MPI Windows10 Version |
Rep Power: 6 ![]() |
Esteemed SU2 users
on windows10 - i9 machine, version MPI 7.5.0 binary downloaded recently Programs running really well in Version MPI 7.3.1 (with 8 cores) now stopping after a warning about "SU2 not compiled for an AVX capable architecture...." Thoughts appreciated - what needs to be added or subtracted from the CFG file Many Thanks |
To add ....
Input files work well on versions 7.3.1 and 7.4.0 but not on 7.5.0 - terminating with the message " SU2 was not compiled for an AVX-capable architecture ". see https .... -SU2 linux-Macos/# compiler-optimizations job aborted: Could it be that compiled mpi windows version of 7.5.0 may need a revision ? Anyone with similar experience ? Many a Thanks rn86j |
bigfoot
Rep Power: 17 ![]() |
The message about AVX-capable architecture is a warning, SU2 should not stop due to this. Are you using AVX-related commands, i.e.
USE_VECTORIZATION= YES |
avx-warning, v7.5.0(mpibinary) |
MPI issues on debian Debian 11 bullseye | flavio73 | SU2 | 8 | April 3, 2024 10:02 |
OpenFOAM.com versus OpenFOAM.org: Which version to use? | wyldckat | OpenFOAM | 19 | March 25, 2023 07:50 |
Building OpenFOAM on IRIX | lakeat | OpenFOAM Installation | 7 | July 16, 2008 07:27 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
MPI and parallel computation | Wang | Main CFD Forum | 7 | April 15, 2004 11:25 |
