Home > Forums > Software User Forums > SU2
The configuration file doesn't have any definition for marker inlet
Old   January 7, 2023, 08:55
Default The configuration file doesn't have any definition for marker inlet
zhangqiang
zhang-qiang is on a distinguished road
I want to test a SU2 project, with the following cfg/su2 file:
1. TestCases/incomp_navierstokes/bend/lam_bend.cfg
2. TestCases/incomp_navierstokes/streamwise_periodic/pipeSlice_3d/pipe1cell3D.su2
Also, I have modified the cfg:
1. line 212, from MESH_FILENAME= mesh_bend_coarse.cgns to MESH_FILENAME= pipe1cell3D.su2
2. line 215, from MESH_FORMAT= CGNS to MESH_FORMAT= SU2
Then, I run SU2_CFD.exe .\lam_bend.cfg, and the bug is reported:
------------------- Geometry Preprocessing ( Zone 0 ) -------------------
Three dimensional problem.
8528 grid points.
4205 volume elements.
3 surface markers.
4205 boundary elements in index 0 (Marker = inlet).
Error in "short unsigned int CConfig::GetMarker_CfgFile_TagBound(std::string) const":
------------------------------ Error Exit -------------------------------
However, in the pipe1cell3D.su2, I find it has defined the inlet in line 12738:
NMARK= 3
MARKER_TAG= inlet
MARKER_ELEMS= 4205
How can I fix the bug "The configuration file doesn't have any definition for marker inlet"?
Ang suggestion is appreciated~~~
zhang-qiang is offline   Reply With Quote
Old   January 7, 2023, 12:00
PENG YAN
PENGGEGE777 is on a distinguished road
It is always recommended to share your config and mesh file.
From the error message you posted, the issue is that you do not have the definition of inlet marker in your config file, not your mesh file.
PENGGEGE777 is offline   Reply With Quote
Old   January 7, 2023, 23:15
zhangqiang
The cfg is actually the TestCases/incomp_navierstokes/bend/lam_bend.cfg, with two lines changing:
And the complete configure file is:
% SU2 configuration file %
% Case description: Ultra coarse GGNS grid with mixed sections for testing %
% Author: Thomas D. Economon %
% Date: 2019.07.26 %
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
% TNE2_EULER, TNE2_NAVIER_STOKES,
% WAVE_EQUATION, HEAT_EQUATION, LINEAR_ELASTICITY,
% POISSON_EQUATION)
SOLVER= INC_NAVIER_STOKES
% Specify turbulence model (NONE, SA, SST)
KIND_TURB_MODEL= NONE
% Mathematical problem (DIRECT, ADJOINT)
MATH_PROBLEM= DIRECT
% Restart solution (NO, YES)
RESTART_SOL= NO
% ---------------- INCOMPRESSIBLE FLOW CONDITION DEFINITION -------------------%
% Density model within the incompressible flow solver.
% Options are CONSTANT (default), BOUSSINESQ, or VARIABLE. If VARIABLE,
% an appropriate fluid model must be selected.
INC_DENSITY_MODEL= CONSTANT
% Solve the energy equation in the incompressible flow solver
INC_ENERGY_EQUATION = NO
% Initial density for incompressible flows
% (1.2886 kg/m^3 by default (air), 998.2 Kg/m^3 (water))
INC_DENSITY_INIT= 1.2886
% Initial velocity for incompressible flows (1.0,0,0 m/s by default)
INC_VELOCITY_INIT= ( 0.1, 0.0, 0.0 )
% Initial temperature for incompressible flows that include the
% energy equation (288.15 K by default). Value is ignored if
% INC_ENERGY_EQUATION is false.
INC_TEMPERATURE_INIT= 288.15
% Non-dimensionalization scheme for incompressible flows. Options are
% INITIAL_VALUES (default), REFERENCE_VALUES, or DIMENSIONAL.
% INC_*_REF values are ignored unless REFERENCE_VALUES is chosen.
INC_NONDIM= INITIAL_VALUES
% Reference density for incompressible flows (1.0 kg/m^3 by default)
INC_DENSITY_REF= 1.0
% Reference velocity for incompressible flows (1.0 m/s by default)
INC_VELOCITY_REF= 1.0
% Reference temperature for incompressible flows that include the
% energy equation (1.0 K by default)
INC_TEMPERATURE_REF = 1.0
% List of inlet types for incompressible flows. List length must
% match number of inlet markers. Options: VELOCITY_INLET, PRESSURE_INLET.
INC_INLET_TYPE= VELOCITY_INLET
% Damping coefficient for iterative updates at pressure inlets. (0.1 by default)
INC_INLET_DAMPING= 0.1
% List of outlet types for incompressible flows. List length must
% match number of outlet markers. Options: PRESSURE_OUTLET, MASS_FLOW_OUTLET
INC_OUTLET_TYPE= PRESSURE_OUTLET
% Damping coefficient for iterative updates at mass flow outlets. (0.1 by default)
INC_OUTLET_DAMPING= 0.1
% --------------------------- VISCOSITY MODEL ---------------------------------%
% Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY, POLYNOMIAL_VISCOSITY).
VISCOSITY_MODEL= CONSTANT_VISCOSITY
% Molecular Viscosity that would be constant (1.716E-5 by default)
MU_CONSTANT= 1.716E-5
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
% Reference origin for moment computation (m or in)
REF_ORIGIN_MOMENT_X = 0.25
REF_ORIGIN_MOMENT_Y = 0.00
REF_ORIGIN_MOMENT_Z = 0.00
% Reference length for pitching, rolling, and yawing non-dimensional moment (m or in)
REF_LENGTH= 1.0
% Reference area for force coefficients (0 implies automatic calculation) (m^2 or in^2)
REF_AREA= 1.0
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker)
% Format: ( marker name, constant heat flux (J/m^2), ... )
MARKER_HEATFLUX= ( WALL1, 0.0, WALL2, 0.0 )
% Inlet boundary marker(s) with the following formats (NONE = no marker)
% Inc. Pressure: (inlet marker, temperature, total pressure, flow_direction_x,
% flow_direction_y, flow_direction_z, ... ) where flow_direction is
% a unit vector.
MARKER_INLET= ( INLET, 288.15, 0.1, 1.0, 0.0, 0.0 )
% Outlet boundary marker(s) (NONE = no marker)
% Compressible: ( outlet marker, back pressure (static thermodynamic), ... )
% Inc. Pressure: ( outlet marker, back pressure (static gauge in Pa), ... )
% Inc. Mass Flow: ( outlet marker, mass flow target (kg/s), ... )
MARKER_OUTLET= ( OUTLET, 0.0 )
% Symmetry boundary marker(s) (NONE = no marker)
MARKER_SYM= ( SYMMETRY )
% Marker(s) of the surface in the surface flow solution file
MARKER_PLOTTING = ( INLET, OUTLET, WALL1, WALL2, SYMMETRY )
% Marker(s) of the surface where the non-dimensional coefficients are evaluated.
MARKER_MONITORING = ( INLET, OUTLET, WALL1, WALL2, SYMMETRY )
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= GREEN_GAUSS
% Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER= 1e2
% Runge-Kutta alpha coefficients
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
% Linear solver or smoother for implicit formulations (BCGSTAB, FGMRES, SMOOTHER_JACOBI,
% SMOOTHER_ILU0, SMOOTHER_LUSGS,
% SMOOTHER_LINELET)
LINEAR_SOLVER= FGMRES
% Preconditioner of the Krylov linear solver (ILU0, LU_SGS, LINELET, JACOBI)
LINEAR_SOLVER_PREC= ILU
% Minimum error of the linear solver for implicit formulations
LINEAR_SOLVER_ERROR= 1E-15
% Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER= 5
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-grid Levels (0 = no multi-grid)
MGLEVEL= 0
% Multi-grid Cycle (0 = V cycle, 1 = W Cycle)
% Multi-grid pre-smoothing level
MG_PRE_SMOOTH= ( 1, 2, 3, 3 )
% Multi-grid post-smoothing level
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 0.75
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 0.75
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= FDS
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations.
% Required for 2nd order upwind schemes (NO, YES)
MUSCL_FLOW= YES
% Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG,
% BARTH_JESPERSEN, VAN_ALBADA_EDGE)
SLOPE_LIMITER_FLOW= NONE
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Number of total iterations
ITER= 11
% Min value of the residual (log10 of the residual)
CONV_RESIDUAL_MINVAL= -8
% Start convergence criteria at iteration number
CONV_STARTITER= 10
% Number of elements to apply the criteria
CONV_CAUCHY_ELEMS= 100
% Epsilon to control the series convergence
CONV_CAUCHY_EPS= 1E-10
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
% Mesh input file format (SU2, CGNS, NETCDF_ASCII)
MESH_FORMAT= SU2
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
SOLUTION_FILENAME= solution_flow.dat
% Restart adjoint input file
SOLUTION_ADJ_FILENAME= solution_adj.dat
TABULAR_FORMAT= CSV
% Output file convergence history (w/o extension)
CONV_FILENAME= history
% Output file restart flow
RESTART_FILENAME= restart_flow.dat
% Output file restart adjoint
RESTART_ADJ_FILENAME= restart_adj.dat
% Output file flow (w/o extension) variables
VOLUME_FILENAME= flow
% Output file adjoint (w/o extension) variables
VOLUME_ADJ_FILENAME= adjoint
% Output Objective function
VALUE_OBJFUNC_FILENAME= of_eval.dat
% Output objective function gradient (using continuous adjoint)
GRAD_OBJFUNC_FILENAME= of_grad.dat
% Output file surface flow coefficient (w/o extension)
SURFACE_FILENAME= surface_flow
% Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAME= surface_adjoint
% Writing solution file frequency
OUTPUT_WRT_FREQ= 1000
SCREEN_OUTPUT= (INNER_ITER, RMS_PRESSURE, RMS_VELOCITY-X, LIFT, DRAG)
Old   January 8, 2023, 03:36
PENG YAN
See your config file;
However, in your mesh, the marker name is 'inlet'.
So change your config file to
MARKER_INLET= ( inlet, 288.15, 0.1, 1.0, 0.0, 0.0 )
let us see what happen
Old   January 8, 2023, 07:44
zhangqiang
Thanks for kindly reply. After change the INLET to inlet, OUTLET to outlet, WALL1 to wall, I can successfully run this SU2 project.
Old   January 8, 2023, 07:53
PENG YAN
Good news, enjoy your journey with SU2.
inlet
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
