January 6, 2023, 20:18 |
Rotorcraft FSI simulation in SU2
I am interested in rotorcraft simulation within the SU2 framework. Generally, rotor simulations are done with solvers with a chimera/overset grid approach since each blade requires different and considerably high motion.
I found the Caradonna tutorial which does not include any blade motion control. Also, there are some published works (not the code itself) from PoliMilano. It seems they have implemented rotation + deformation of each blade. I am a bit worried about mesh quality when we consider the amount of deformation required. I would like to get an opinion about what will be a good way to simulate rotorcraft in SU2, which options are available in the current situation, and what kind of development opportunities are possible? Best, Kursat |
January 12, 2023, 09:49 |
Wally Maier
Rep Power: 7 |
Hi Kursat,
I am no expert in rotorcraft/turbomachinery in CFD. But as a heads up, the main development of SU2 does not have any overset grid capability. I would suggest trying to look for some papers on turbomachinery within SU2. Hope this provides a little bit of guidance. Good luck. |
January 14, 2023, 11:20 |
#3 | |
Thank you very much, I look at the GitHub page and it seems currently no one is working on overset grid future. Probably multizone grids with some sliding mesh + deformation can give what I would like to have. Turbomachinery papers are generally non-deformable bodies, with no pitch control, etc. My main problem is surface orientation + deformation of the body. |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
SU2 NACA0012 Transitional flow simulation Convergence Issues | morgJ | SU2 | 0 | July 21, 2022 08:42 |
Need Help With SU2 Supersonic Simulation | Moose21 | SU2 | 2 | July 18, 2022 18:57 |
[solids4Foam] FSI case does not converge, foam extend 4.0 | MFWilliams | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 12 | May 13, 2022 09:35 |
Wing FSI simulation: Shell elements or 3D solid body? | frossi | CFX | 3 | June 15, 2016 21:02 |
