"A converter from CGNS to the native format is also built into SU2." But where? |
December 30, 2022, 05:37 |
Ashish Magar
Rep Power: 10 |
Does anyone has any insights on how cgns mesh can be converted to native su2 format in SU2. It says in documentation that a converter is available but I couldn't find any code or cfg regarding it.
Thanks |
December 30, 2022, 08:11 |
bigfoot
Rep Power: 21 |
You can use SU2_DEF for this, the tutorial is here:
https://su2code.github.io/tutorials/Inviscid_Wedge/ |
December 30, 2022, 09:51 |
Ashish Magar
Rep Power: 10 |
Thanks..!!
By the time I found a workaround. As I came across threads showing high memory usage with CGNS mesh files, it was discussed that using SU2 format mesh files had lower memory per procs. I used utility SU2_MSH from v6.0.1 to convert my CGNS mesh to SU2 as all other trials with meshio failed. I dont know for some reason SU2_MSH was deprecated in newer versions. The SU2 formatted mesh files are compatible with current version of solver v7.5.0 . Another question: Is SU2_CFD supposed to convert mesh file to mentioned formats in cfg file under keyword MESH_OUT_FILENAME? Because it doesnt even after the simulation is terminated smoothly. |
January 1, 2023, 16:17 |
#4 | |
bigfoot
Rep Power: 21 |
OUTPUT_FILES= MESH |
Salome cgns format mesh to SU2 | JPBLourenco | SU2 | 19 | November 18, 2019 03:11 |
Cannot convert CGNS to SU2 native mesh | paulzhang | SU2 | 0 | August 31, 2016 00:22 |
SU2 not built with CGNS support. | maximus23 | SU2 Installation | 5 | May 11, 2016 13:05 |
CGNS mesh format | B_Ouissem | SU2 | 2 | August 20, 2015 15:10 |
OpenFOAM native format data visualization and workflow | zeliboba | OpenFOAM Post-Processing | 0 | September 12, 2008 09:44 |
