Failing to recreate experimental data - NACA0021 |
December 19, 2022, 08:35 |
Philip Agenmonmen
Rep Power: 4 |
Hello All,
I’m quite new to SU2 and I have been struggling to recreate experimental data for a NACA0021 airfoil. I have only managed to achieve a maximum lift/drag ratio of 4. However, the data I am trying to recreate has a lift to drag ratio of 23 (at 10° AoA). Link: https://www.researchgate.net/profile...1-aerofoil.pdf. I have based my config file on the Turbulent NACA0012 tutorial code. Link: https://su2code.github.io/tutorials/...lent_NACA0012/. Here's a list of things I have tried so far:
I’ve attached my config file, mesh & an image of the mesh quality generated (I could not attach the 500c mesh as it was too big)
I’m thinking it is something to do with my configuration settings, however I’m not sure what it could be. Any help would be greatly appreciated, Thanks Philip |
January 6, 2023, 11:57 |
Potential Source of issue
Philip Agenmonmen
Rep Power: 4 |
I believe I may have found a potential source of the issue.
It seems that joining the airfoil up with normal lines is creating a jagged profile so I have tried to create an airfoil using multiple different curve types (B-spline, Spline and Bezier). However, the mesh does not recognise the airfoil boundary when I use these curves. Here is the script used (Bezier curve): //+ Point(1) = {1.0, 0.00221, 0, 1.0}; //+ Point(2) = {0.95, 0.01412, -0, 1.0}; //+ Point(3) = {0.90, 0.02534, -0, 1.0}; //+ Point(4) = {0.8, 0.04591, -0, 1.0}; //+ Point(5) = {0.7, 0.06412, -0, 1.0}; //+ Point(6) = {0.6, 0.07986, -0, 1.0}; //+ Point(7) = {0.5, 0.09265, -0, 1.0}; //+ Point(8) = {0.4, 0.10156, -0, 1.0}; //+ Point(9) = {0.3, 0.10504, -0, 1.0}; //+ Point(10) = {0.25, 0.10397, -0, 1.0}; //+ Point(11) = {0.2, 0.1004, -0, 1.0}; //+ Point(12) = {0.15, 0.09354, -0, 1.0}; //+ Point(13) = {0.1, 0.08195, -0, 1.0}; //+ Point(14) = {0.075, 0.0735, -0, 1.0}; //+ Point(15) = {0.05, 0.06221, -0, 1.0}; //+ Point(16) = {0.025, 0.04576, -0, 1.0}; //+ Point(17) = {0.0125, 0.03315, -0, 1.0}; //+ Point(18) = {0, 0, -0, 1.0}; //+ Point(19) = {0.0125, -0.03315, -0, 1.0}; //+ Point(20) = {0.025, -0.04576, -0, 1.0}; //+ Point(21) = {0.05, -0.06221, -0, 1.0}; //+ Point(22) = {0.075, -0.0735, -0, 1.0}; //+ Point(23) = {0.1, -0.08195, -0, 1.0}; //+ Point(24) = {0.15, -0.09354, -0, 1.0}; //+ Point(25) = {0.2, -0.1004, -0, 1.0}; //+ Point(26) = {0.25, -0.10397, -0, 1.0}; //+ Point(27) = {0.3, -0.10504, -0, 1.0}; //+ Point(28) = {0.4, -0.10156, -0, 1.0}; //+ Point(29) = {0.5, -0.09265, -0, 1.0}; //+ Point(30) = {0.6, -0.07986, -0, 1.0}; //+ Point(31) = {0.7, -0.06412, -0, 1.0}; //+ Point(32) = {0.8, -0.04591, -0, 1.0}; //+ Point(33) = {0.9, -0.02534, -0, 1.0}; //+ Point(34) = {0.95, -0.01412, -0, 1.0}; //+ Point(35) = {2.5, 50, 0, 1.0}; //+ Point(36) = {2.5, -50, 0, 1.0}; //+ Point(37) = {2.8, 0, 0, 1.0}; //+ Circle(34) = {35, 37, 36}; //+ Point(38) = {50, 50, 0, 1.0}; //+ Point(39) = {50, -50, 0, 1.0}; //+ Line(35) = {35, 38}; //+ Line(36) = {38, 39}; //+ Bezier(37) = {1, 2, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 1}; //+ Line(38) = {36, 39}; //+ Physical Curve("farfield", 39) = {34, 35, 36, 38}; //+ Physical Curve("airfoil", 40) = {37}; //+ Curve Loop(1) = {35, 36, -38, -34}; //+ Curve Loop(2) = {37}; //+ Plane Surface(1) = {1, 2}; I'll also attach an image of the mesh going through the airfoil Any help would be much appreciated! Last edited by PhilipA; January 6, 2023 at 12:14. Reason: Visual changes |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 21:06 |
Computed Pressure Drop is lower than experimental data | Ash Kot | FLUENT | 2 | May 17, 2017 10:41 |
UDF for Mapping 3D Experimental Data (Heat Generation) to Mesh | jbo214 | Fluent UDF and Scheme Programming | 1 | May 15, 2017 16:47 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 15:06 |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 05:46 |
