Home > Forums > Software User Forums > SU2
Code doesn't run in parallel mode, exit codes 9 & 139
Old   December 13, 2022, 12:07
Exclamation Code doesn't run in parallel mode, exit codes 9 & 139
Esdras
Esdras is on a distinguished road
Hello, I'm relatively new to SU2 and Linux in general, I had previously used SU2 in normal mode and parallel mode successfully in window's WSL in one computer. I'm now in another machine and installed Mint, I downloaded SU2, edited .bashrc correctly, and installed MPICH via the command line with "sudo apt install mpich", I then ran a simulation , that I had successfully run on another computer, in normal mode and it worked, I then tried running it in parallel mode and I get the exit codes 9 and 139, depending on the number of cores I use. I tried deleting and downloading again SU2, and removing and installing again mpich but it didn't work, I googled the error but couldn't find it in a situation like mine, these errors occur right at the beginning of the simulation. Thanks in advance.
Screenshots of the errors:
Esdras is offline   Reply With Quote
Old   December 16, 2022, 17:12
Esdras
UPDATE (SOLVED):
I ran another pogram with mpich to test if it was working correctly and it was, so I figured the problem was an imcompatibility between mpich and SU2. So I decided to install it building from source, after that the problem was solved. I only had another little issue while installing it, the su2 installer was saying something about my python version not being valid, so I downloaded the Anaconda version and that solved it.
exit code, mpich, parallel
sloshingTank3D6DoF failed to run in parallel phsieh2005 OpenFOAM Running, Solving & CFD 1 May 19, 2023 00:51
Automatically switched to run in parallel -t1 mode MsRuby Fluent UDF and Scheme Programming 6 June 16, 2018 07:37
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
How to run icoFsiFoam in parallel mode? AsDF OpenFOAM Running, Solving & CFD 2 February 21, 2014 08:56
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
