Home > Forums > Software User Forums > SU2
Multizone simulation doesn't output history.csv file
Old   November 22, 2022, 07:38
Default Multizone simulation doesn't output history.csv file
Orangade is on a distinguished road
Hello everyone, I am trying to run a multizone simulation with SU2 v7.2.1 with 2 zones which differ in their rigid motion properties.
I have the following variables in the main configuration file:
TABULAR_FORMAT= CSV
CONV_FILENAME= history
HISTORY_OUTPUT= (ITER,...)
HISTORY_WRT_FREQ_INNNER= 1
I read in the "History and Solution Output" in the Users Guide that if I run a multizone problem, a file "history_multizone.dat" should be created in addition to the history files of each zone. However, we have no history file at all.
Thank you!
Orangade is offline   Reply With Quote
Old   November 22, 2022, 08:38
bigfoot
bigfootedrockmidget is on a distinguished road
Writing a history file seems to work for me (sample size of N=1), but in your case I think the history filename will be "history.csv". So the best thing is:
1. upgrade to the latest version of SU2
2. try the multizone testcases in the TestCases folder and verify that they work correctly for you.
3. copy the correct settings to your own configuration
4. if it is still not working for your own testcase, please provide a minimal testcase to reproduce the issue.
bigfootedrockmidget is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
