Robert
Rep Power: 3 ![]() |
I have been working on replicating the Incompressible Streamwise tutorial case however I'm finding that generating a new mesh using the GMSH script makes the solver crash stating NPOIN is not the same as mesh file, even though I have made no change to the actual script.
bigfoot
Rep Power: 17 ![]() |
in the su2 mesh file, check that you actually have the points, the connectivities and the markers present.
Then check that you you do not select 'save all point' when saving an su2 file. Also make sure that you actually regenerate the mesh before saving, and that no errors have occured during the generation |
#3 | |
Robert
Streamwise Periodic Solver | decenu | SU2 | 1 | November 15, 2022 13:44 |
Streamwise periodic heat trasnfer | AlmostSurelyRob | OpenFOAM | 10 | March 31, 2022 13:57 |
[ICEM] how to define periodic in icem ? | mingersai | ANSYS Meshing & Geometry | 1 | February 3, 2012 17:46 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Streamwise periodic heat transfer | Novice | CFX | 0 | March 4, 2006 08:14 |
