November 10, 2022, 10:04 |
MULTIZONE with species transport bombing
Robert Tramel
Rep Power: 4 |
I am trying to run an analysis that involves multizone fluid-fluid flow with species. To create a simple test case I took the .su2 mesh file for the incompressible flow/species transport tutorial and duplicated and shifted one mesh to create a simple multizone case. The problem works beautifully without species transport but when I add that in the code bombs in the setup phase and I get the following error message. Can anyone help me out here?
Error in "virtual void CMultizoneOutput::SetMultizoneHistoryOutputFields( const COutput* const*, const CConfig* const*)": ------------------------------------------------------------------------- Per Surface output group unknown: SPECIES_COEFF_SURF ------------------------------ Error Exit ------------------------------- |
November 10, 2022, 13:28 |
bigfoot
Rep Power: 21 |
We have not implemented/tested this keyword for multizone yet. You could first try by removing the SPECIES_COEFF_SURF keyword from the config file. Do you need to optimize a species related objective? |
November 10, 2022, 18:37 |
Robert Tramel
Rep Power: 4 |
I never included the term in the cfg files because I didn't know it was needed. Should I be defining it? I am not trying to optimize anything species related. I'm trying multizone because I want to use a body force in certain zones as a crude but simple way to mimic a porous media.
November 11, 2022, 03:46 |
bigfoot
Rep Power: 21 |
I did a quick test. If I run the CHT case:
https://su2code.github.io/tutorials/Static_CHT/ and add species transport, I do not get this message. I just add this to the flow_cylinder.cfg fluid setup: Code:
% -------------------- SCALAR TRANSPORT ---------------------------------------% % KIND_SCALAR_MODEL= SPECIES_TRANSPORT DIFFUSIVITY_MODEL= CONSTANT_DIFFUSIVITY DIFFUSIVITY_CONSTANT= 0.001 % CONV_NUM_METHOD_SPECIES= SCALAR_UPWIND MUSCL_SPECIES= NO SLOPE_LIMITER_SPECIES = NONE % TIME_DISCRE_SPECIES= EULER_IMPLICIT % SPECIES_INIT= 1.0, 0.0 SPECIES_CLIPPING= YES SPECIES_CLIPPING_MIN= 0.0, 0.0 SPECIES_CLIPPING_MAX= 1.0, 1.0 Maybe you can check what the difference in setup is. Can you share your setup somewhere? If you can create a bug report on github with a case that reproduces this error, we can look into it. https://github.com/su2code/SU2/issues |
November 11, 2022, 21:11 |
Robert Tramel
Rep Power: 4 |
The problem comes when you specify MARKER_ANALYZE to compute mass flux . However when you remove that there is no communication of species information across the interface. as can be seen in the following images of velocity, species_0, and species_1
November 16, 2022, 09:33 |
bigfoot
Rep Power: 21 |
OK, there were actually 2 problems here. One is that the species mass fractions were not transported across the zone interface. The other is that for MARKER_ANALYZE, we did not add species information, but later in the code we assumed that it was present. Both are now fixed in the feature branch, but it will be a while before it ends up in the master version. In the mean time, you could clone the SU2 git repository and then do a git checkout feature_species_multizone and compile the fixed branch yourself. Thanks for spotting the problem! |
November 19, 2022, 19:19 |
bigfoot
Rep Power: 21 |
By the way, in the develop branch, species transport has been extended with species dependent properties. the keyword PASSIVE_SCALAR has therefore also been replaced by SPECIES_TRANSPORT
If you clone the code from github, you can find some examples in the Testcases/species_transport directory |
incompressible, multizone, species transport |
Modelling Biomass Combustion via Species Transport | Racheal | FLUENT | 39 | January 8, 2022 08:42 |
UDF for Sorption in Species Transport through Porous Medium | Kosch | Fluent UDF and Scheme Programming | 6 | October 21, 2020 18:46 |
Direct numerical simulation of species transport equation with phase change | Pmaroul | Main CFD Forum | 2 | October 12, 2018 17:02 |
A question about species box of species transport model | tjushang | FLUENT | 2 | June 25, 2014 08:56 |
user defined scalar vs species transport | gvj_mech | FLUENT | 0 | March 27, 2014 15:33 |
