Robert
Rep Power: 3 ![]() |
I am working on the multiphysics tutorial from SU2, specifically the static CHT simulation.
I am looking to recreate a very similar simulation, using a larger grid with more obstacles. The issue I’m running into is creating the mesh as I don`t fully understand the structure. The mesh I created uses a farfield, outer cylinder wall and inner cylinder wall. The mesh uses multiple zones but modelling it in GMSH seems tricky. 1. The tutorial defines a third zone called Core1 for the cylinders. I am struggling to understand what this mesh represents. 2. Is the cylinder thickness modelled as a surface? I would be delighted if anyone could shed some light over how would one generate the mesh from said tutorial: https://su2code.github.io/tutorials/Static_CHT/ |
bigfoot
Rep Power: 17 ![]() |
The cylinder is hollow and we set the wall temperature of the inner circular boundary. This would be akin to a hollow tube with cooling water running through it. In this setup, the cooling water is not simulated, only the hollow tube. We simply assume that the water keeps the wall of the water channel at a constant temperature. 2. Is the cylinder thickness modeled as a surface? Yes, all physical 2D zones are surfaces. here is some further info: https://su2code.github.io/docs_v7/Multizone/ |
#3 | |
Robert
Ole Burghardt
Rep Power: 10 ![]() |
there are four physical zones (sub-meshes, if you like) in the mesh, one for the fluid flow zone, three for the solid zones. The boundaries in the fluid flow mesh are called farfield, cylinder_outer1, cylinder_outer2 and cylinder_outer3. The boundaries in solid zone mesh X are called cylinder_innerX, coreX. (The solid zones are annuli, the outer perimeter is called cylinder_inner, the inner perimeter is called core.) The CHT coupling between the fluid zone and the solid zones is formed by exchanging data between cylinder_outerX and cylinder_innerX. At the cores, a temperature boundary condition is imposed. For meshing it might be easiest, or actually the only way, to create meshes for each domain seperately and to concatenate them later on. The mesh file used for this tutorial is in text format, just check it out to see how it's done. Does this help? :-) |
#5 | |
Robert
Thank you for the advice. You have opened my eyes! It worked!!!!! The answer to my question is exactly your suggestion i.e. concatenate the meshes together. Still have a long way to go as for optimizing and everything but you might have saved a poor's student's week haha! |
Ole Burghardt
You're welcome :-)
Just out of curiosity, what are you working on? |
na
Rep Power: 8 ![]() |
Just to add a little bit of resource/inspiration that might help with a few things:
1. video that covers general aspects of multizone simulations/setups https://www.youtube.com/watch?v=ez368rDYrFk (no guarantee that everything is still up to date, but e.g. the mesh concatenation definitely is) 2. A repository with a few gmsh meshes (also a few multizone ones, inidicated with e,g, '2zones' in the folder name). Take e.g. folder '18__3D-2Zone-pin-in-crossflow' for an easy setup. I pretty much only made structured meshes so setups might be easier for you but I generally create the interface boundary at the beginning that gets used for all relevant zones to have a single source of origin, all zone-specific stuff then comes later in the file https://github.com/TobiKattmann/Meshes/ Maybe this of use for you |
Robert
#9 | |
Robert
#10 |
Ole Burghardt
Sounds like wrong settings or a corrupted mesh. We'd need to have a look on the output and/or config files
#11 | |
Robert
I'm attaching the config file here and a snip of the mesh, maybe you can have a look. The one thing that I can see different between my mesh and the tutorial is that I am using an unstructured grid and obviously a different array with more cylinders. Unfortunately, I can't seem to upload the mesh as it's too large. The markers that I am using are "Inlet" and "Outlet" for left- and right-hand sides, "cylinderx" (x = 1:15) for each cylinder surface and symmetry for the top and bottom sides which exclude the cylinders. |
#12 | |
Robert
The config file for this is attached along with the resulting history excel file. |
#13 |
bigfoot
Is this last case a fluid-domain simulation only? What is the mesh quality of the mesh? And the Reynolds number? The mesh also looks extremely fine close to the cylinder walls. For such simple meshes it can be very beneficial to use structured meshes instead of unstructured meshes.
#14 | |
Robert
cht modelling, gmsh, gmsh cylinder, mesh, su2 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
