Multiphysics (Conjugate Heat Transfer) in Parallel? |
Rep Power: 3 ![]() |
I would like to use SU2 to run some steady conjugate heat transfer simulations. When testing out one of the tutorials (Static Conjugate Heat Transfer), I attempted to run using parallel_computation.py (which is what I have always done for running CFD sims), but "Parallel computation script not compatible with MULTIPHYSICS solver." was sadly printed to the console. Does anyone happen to know of any way that I could still run in parallel somehow? Or is it just completely hopeless besides for writing my own "parallel_computation" script to do this (which I have absolutely no clue how to do). |
Pedro Gomes
Rep Power: 13 ![]() |
Just use mpirun -n "number of cores" Su2_cfd your_config.cfg
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Conjugate heat transfer | ali_1364reza | FLUENT | 1 | May 31, 2012 09:38 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer problem | hvem10 | FLUENT | 2 | October 29, 2009 17:31 |
