Shuang Qiu
Rep Power: 5 ![]() |
Hi all,
I tried to simulate a supersonic cylinder problem with an O-mesh generated in Gmsh. When start simulating the geometry processing gives the message "0 interior elements before parallel partitioning" and quit from simulation. Attached is my Gmsh script and my config file, and a screenshot of my mesh. Can anyone help me with this? |
Brandon Gleeson
Rep Power: 8 ![]() |
Hi Shijian-20,
Maybe try to compound the two halves of your grid by issuing the "Mesh" → "Define" → "Compound" → "Surface" command in the GUI, or add this line to your *.geo file: //+ Compound Surface {1, 2}; I'm just curious as to the reason for running the FEM solver for this problem? I'm not sure what the grid requirements are for that, but I'm curious if GMESH's 3rd order grid will work with that solver. Have you tried just running a 1st order grid with the FVM flow solver to make sure the basics of your problem setup are OK? --Brandon-- |
gmsh cylinder, su2 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[Workbench] Meshing and export mesh from STL geometry | alerfreire | ANSYS Meshing & Geometry | 0 | March 26, 2013 09:25 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
