Home > Forums > Software User Forums > SU2
Setting Different domain/zone
Old   September 9, 2022, 08:06
Default Setting Different domain/zone
Antimo
Shanks is on a distinguished road
I am new on SU2, I try to simulate a field around an axisymmetric body. I have a mesh 3D with following zone "Farfield", "Body", "Outlet", "Symmetric plane". I setting my file .cfg and solve the field, when I postprocessing the data, the domain I see is unique, all zone is under "Zone 0" and I can't activate or deactivate the single zone.
Is there an option to allow me to setting zone separate in file .cfg so I can see a single zone in postprocessing process?
The mesh is an unstructured mesh build in ICEM CFD and the postprocessing program is Tecplot; there isn't a different law for the mesh, every zone and part have the same mesh.
Thanks for your attention!
Shanks is offline   Reply With Quote
Old   September 11, 2022, 14:32
bigfoot
bigfootedrockmidget is on a distinguished road
I do not use tecplot, so I do not know what the limitations are here. However, if you save the results as PARAVIEW_MULTIBLOCK, then you get the separated zones in paraview.
bigfootedrockmidget is offline   Reply With Quote
Old   September 12, 2022, 10:46
Antimo
Thanks for your answer. I try it!
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
