August 17, 2022, 11:28 |
Error on trying to run the parallel code
Hi!
I wanted to utilize the parallel version of SU2 in a project of mine. I've installed the needed MPI (I use SU2 on windows) but yet, an error message pops up while the output files are being written. |
August 17, 2022, 11:40 |
bigfoot
Rep Power: 18 |
so what's the error message?
August 17, 2022, 12:14 |
file write error, parallel computation |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
Foam-Extend 4.1 Mpi doesn't exit gracefully at the end of parallel run | EternalSeekerX | OpenFOAM Running, Solving & CFD | 0 | May 30, 2021 03:04 |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 22:33 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
SnappyHexMesh OF-1.6-ext crashes on a parallel run | norman1981 | OpenFOAM Bugs | 5 | December 7, 2011 12:48 |
