Home > Forums > Software User Forums > SU2
MPI Start Errors
Old   August 2, 2022, 08:57
Default MPI Start Errors
Ercan Umut
CleverBoy is on a distinguished road
Hello everybody,
I am trying the Inviscid Onera M6 tutorial with parallel computing but I encounter with the erros below:
parallel_computation.py -f inv_ONERAM6.cfg -n 3 NP
Traceback (most recent call last):
  File "/usr/local/bin/parallel_computation.py", line 30, in <module>
    sys.path.append(os.environ['SU2_RUN'])
  File "/usr/lib/python3.9/os.py", line 679, in __getitem__
    raise KeyError(key) from None
KeyError: 'SU2_RUN'
Anyone knows why is this happening and how can I solve this?
CleverBoy is offline   Reply With Quote
Old   August 3, 2022, 08:47
na
TKatt is on a distinguished road
Your shell does not know about the environmental variable SU2_RUN which contains the path to your SU2 binaries. In case you compile code yourself: when running meson it will give you the commands to execute in your shell to set the environmental variable
Otherwise just type in your shell (at least in linux)
export SU2_RUN="/path/to/your/SU2-binaries-folder"
TKatt is offline   Reply With Quote
Old   August 8, 2022, 11:15
Ercan Umut
Dear Tkatt,
Thanks for your reply and I am sorry for the delay in answering.
I tried what you said. More problems occurred
3 total processes failed to start
  File "/usr/local/bin/parallel_computation.py", line 110, in <module>
    main()
  File "/usr/local/bin/parallel_computation.py", line 55, in main
    parallel_computation( options.filename    ,
  File "/usr/local/bin/parallel_computation.py", line 88, in parallel_computation
    info = SU2.run.CFD(config)
  File "/usr/local/bin/SU2/run/interface.py", line 112, in CFD
    run_command( the_Command )
  File "/usr/local/bin/SU2/run/interface.py", line 270, in run_command
    raise exception(message)
RuntimeError: Path = /home/ercan/SU2-NEMO/SU2/Inviscid_ONERAM6/,
Command = mpirun -n 3 /path/to/your/SU2-binaries-folder/SU2_CFD config_CFD.cfg
SU2 process returned error '132'
mpirun was unable to launch the specified application as it could not access
or execute an executable:
Executable: /path/to/your/SU2-binaries-folder/SU2_CFD
Node: ercanumut
while attempting to start process rank 0.
Old   August 8, 2022, 11:33
bigfoot
bigfootedrockmidget is on a distinguished road
You should of course replace /path/to/your/SU2-binaries-folder with the actual location of your SU2 binaries. When you run meson, meson will give this information to you on the screen. Do you run meson and ninja on a command line from a console?
bigfootedrockmidget is offline   Reply With Quote
Old   August 8, 2022, 13:38
Ercan Umut
Oh sorry about that, I didn't realize it while I was rushing out from work . I did that way and it worked. Thank you for your help
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
