Home > Forums > Software User Forums > SU2
Volumetric flow rate
Old   July 14, 2022, 05:34
Post Volumetric flow rate
Praveen
Praveen_krish is on a distinguished road
Hey, everyone I am currently dealing with a case where I have been provided with only the volumetric flow rate through an inlet.(no velocity or area description).
I want to use this as BC for the inlet in SU2 but there is no volumetric flow BC in SU2. I checked and there is only mass flow case where I need the velocity at the inlet. I know the density is there any way I can provide this boundary condition without further information.
Thanks in advance.
Praveen_krish is offline   Reply With Quote
Old   July 16, 2022, 03:26
bigfoot
bigfootedrockmidget is on a distinguished road
No, you need the surface area to compute the velocity. You'll need to compute the surface area from the geometry information
bigfootedrockmidget is offline   Reply With Quote
Outlet BC: fixed outlet volumetric flow rate with reversed flow juanf OpenFOAM Pre-Processing 0 July 29, 2021 07:17
rhoSimpleFoam with specified mass flow rate at outlet ishan_ae OpenFOAM Running, Solving & CFD 3 September 1, 2020 02:11
Mass flow rate history over solution step- rhoSimpleFoam gian93 OpenFOAM Post-Processing 0 December 8, 2019 11:20
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Specify mass flow rate for periodic boundary conditions in channel flow lion1990 OpenFOAM Running, Solving & CFD 1 July 9, 2018 18:46
