July 12, 2022, 13:09 |
Change Design Variables
Zahra
Rep Power: 4 |
Hi everyone,
I am trying to optimize an airfoil with my own mesh to minimize Cd with fixed CL. I completed the optimization, which has 20 points as design variables (DEFINITION_DV) on each surface, and it worked well. Now I want to change the number of design variables to 10 points and 25 points. So I just changed the "DEFINITION_DV" with the same mesh and same code. But it does not work anymore. Do you have any idea about how can I deal with this problem? Do I need to change any other thing rather than DEFINITION_DV? % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) SOLVER= RANS % % Specify turbulent model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SA % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= YES % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 0.754 % % Angle of attack (degrees, only for compressible flows) AOA= 2.57 % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 288.15 % % Reynolds number (non-dimensional, based on the free-stream values) REYNOLDS_NUMBER= 6.2E6 % % Reynolds length (1 m by default) REYNOLDS_LENGTH= 1.0 % -------------------------- CL DRIVER DEFINITION -----------------------------% % % Activate fixed lift mode (specify a CL instead of AoA, NO/YES) FIXED_CL_MODE= YES % % Target coefficient of lift for fixed lift mode (0.80 by default) TARGET_CL= 0.71 % % Estimation of dCL/dAlpha (0.2 per degree by default) DCL_DALPHA= 0.2 % % Maximum number of iterations between AoA updates UPDATE_AOA_ITER_LIMIT= 100 % % Number of iterations to evaluate dCL/dAlpha at the end of the simulation ITER_DCL_DALPHA= 500 % % Evaluate dObjFunc/dCL during runtime (YES) or use the value stored in the % direct solution file (NO). EVAL_DOF_DCX= NO % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 1.0 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( AIRFOIL, 0.0 ) % % Farfield boundary marker(s) (NONE = no marker) MARKER_FAR= ( FARFIELD ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( AIRFOIL ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( AIRFOIL ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 5.0 % % Number of total iterations ITER= 200000 % % Objective function in gradient evaluation (DRAG, LIFT, SIDEFORCE, MOMENT_X, % MOMENT_Y, MOMENT_Z, EFFICIENCY) OBJECTIVE_FUNCTION= DRAG % ----------- SLOPE LIMITER AND DISSIPATION SENSOR DEFINITION -----------------% % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= YES % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_TURB= NO % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the adjoint flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_ADJFLOW= YES % % Slope limiter (NONE, VENKATAKRISHNAN, BARTH_JESPERSEN, VAN_ALBADA_EDGE, % SHARP_EDGES, WALL_DISTANCE) SLOPE_LIMITER_ADJFLOW= VENKATAKRISHNAN % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence adjoint equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_ADJTURB= NO % % Slope limiter (NONE, VENKATAKRISHNAN, BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_ADJTURB= VENKATAKRISHNAN % % Coefficient for the Venkat's limiter (upwind scheme). A larger values decrease % the extent of limiting, values approaching zero cause % lower-order approximation to the solution (0.05 by default) VENKAT_LIMITER_COEFF= 0.05 % % Coefficient for the adjoint sharp edges limiter (3.0 by default). ADJ_SHARP_LIMITER_COEFF= 3.0 % % Freeze the value of the limiter after a number of iterations LIMITER_ITER= 999999 % % 1st order artificial dissipation coefficients for % the Lax–Friedrichs method ( 0.15 by default ) LAX_SENSOR_COEFF= 0.15 % % 2nd and 4th order artificial dissipation coefficients for % the JST method ( 0.5, 0.02 by default ) JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % 1st order artificial dissipation coefficients for % the adjoint Lax†"Friedrichs method ( 0.15 by default ) ADJ_LAX_SENSOR_COEFF= 0.15 % % 2nd, and 4th order artificial dissipation coefficients for % the adjoint JST method ( 0.5, 0.02 by default ) ADJ_JST_SENSOR_COEFF= ( 0.5, 0.02 ) % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= JST % % Entropy fix coefficient (0.0 implies no entropy fixing, 1.0 implies scalar % artificial dissipation) ENTROPY_FIX_COEFF= 0.001 % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % % Reduction factor of the CFL coefficient in the turbulence problem CFL_REDUCTION_TURB= 1.0 % ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, ROE) CONV_NUM_METHOD_ADJFLOW= JST % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT) TIME_DISCRE_ADJFLOW= EULER_IMPLICIT % % Relaxation coefficient RELAXATION_FACTOR_ADJOINT= 1.0 % % Reduction factor of the CFL coefficient in the adjoint problem CFL_REDUCTION_ADJFLOW= 0.8 % % Limit value for the adjoint variable LIMIT_ADJFLOW= 1E6 % ----------------------- GEOMETRY EVALUATION PARAMETERS ----------------------% % % Marker(s) of the surface where geometrical based function will be evaluated GEO_MARKER= ( AIRFOIL ) % % Description of the geometry to be analyzed (AIRFOIL, WING, FUSELAGE) GEO_DESCRIPTION= AIRFOIL % % Geometrical evaluation mode (FUNCTION, GRADIENT) GEO_MODE= FUNCTION % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -20 % % Start convergence criteria at iteration number CONV_STARTITER= 10 % % Number of elements to apply the criteria CONV_CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CONV_CAUCHY_EPS= 1E-6 % % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= ThreeT_v2.su2 % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FILENAME= solution_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (PARAVIEW, TECPLOT, STL) TABULAR_FORMAT= CSV % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % Writing solution file frequency OUTPUT_WRT_FREQ= 10000 % % % Screen output SCREEN_OUTPUT=(INNER_ITER, RMS_DENSITY, RMS_NU_TILDE, LIFT, DRAG) % % Output files OUTPUT_FILES= (RESTART, PARAVIEW, SURFACE_PARAVIEW, SURFACE_CSV) % ----------------------- DESIGN VARIABLE PARAMETERS --------------------------% % Kind of deformation (FFD_SETTING, FFD_CONTROL_POINT_2D, FFD_CAMBER_2D, FFD_THICKNESS_2D, % HICKS_HENNE, PARABOLIC, % NACA_4DIGITS, DISPLACEMENT, ROTATION, FFD_CONTROL_POINT, % FFD_NACELLE, FFD_TWIST, FFD_ROTATION, % FFD_CAMBER, FFD_THICKNESS, SURFACE_FILE) DV_KIND= HICKS_HENNE % % Marker of the surface to which we are going apply the shape deformation DV_MARKER= ( AIRFOIL ) % % Parameters of the shape deformation % - HICKS_HENNE ( Lower Surface (0)/Upper Surface (1)/Only one Surface (2), x_Loc ) % - NACA_4DIGITS ( 1st digit, 2nd digit, 3rd and 4th digit ) % - PARABOLIC ( Center, Thickness ) % - DISPLACEMENT ( x_Disp, y_Disp, z_Disp ) % - ROTATION ( x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % - OBSTACLE ( Center, Bump size ) % - FFD_CONTROL_POINT ( FFD_BoxTag ID, i_Ind, j_Ind, k_Ind, x_Disp, y_Disp, z_Disp ) % - FFD_DIHEDRAL_ANGLE ( FFD_BoxTag ID, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % - FFD_TWIST_ANGLE ( FFD_BoxTag ID, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % - FFD_ROTATION ( FFD_BoxTag ID, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % - FFD_CAMBER ( FFD_BoxTag ID, i_Ind, j_Ind ) % - FFD_THICKNESS ( FFD_BoxTag ID, i_Ind, j_Ind ) % - FFD_VOLUME ( FFD_BoxTag ID, i_Ind, j_Ind ) DV_PARAM= ( 1, 0.5 ) % % New value of the shape deformation DV_VALUE= 0.01 % --------------------- OPTIMAL SHAPE DESIGN DEFINITION -----------------------% % Available Objective functions % DRAG, LIFT, SIDEFORCE, PRESSURE, FORCE_X, FORCE_Y, % FORCE_Z, MOMENT_X, MOMENT_Y, MOMENT_Z, EFFICIENCY, % EQUIVALENT_AREA, THRUST, TORQUE, FREESURFACE % Optimization objective function with scaling factor, separated by semicolons. % To include quadratic penalty function: use OPT_CONSTRAINT option syntax within the OPT_OBJECTIVE list. % ex= Objective * Scale OPT_OBJECTIVE= DRAG % % Optimization constraint functions with pushing factors (affects its value, not the gradient in the python scripts), separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= ( MOMENT_Z < 0.093 ) * 0.001; ( AIRFOIL_THICKNESS > 0.12 ) * 0.001 % % Factor to reduce the norm of the gradient (affects the objective function and gradient in the python scripts) % In general, a norm of the gradient ~1E-6 is desired. OPT_GRADIENT_FACTOR= 1E-6 % % Factor to relax or accelerate the optimizer convergence (affects the line search in SU2_DEF) % In general, surface deformations of 0.01'' or 0.0001m are desirable OPT_RELAX_FACTOR= 1E2 % % Maximum number of iterations OPT_ITERATIONS= 100 % % Requested accuracy OPT_ACCURACY= 1E-10 % % Optimization bound (bounds the line search in SU2_DEF) OPT_LINE_SEARCH_BOUND= 1E6 % % Upper bound for each design variable (bound in the python optimizer) OPT_BOUND_UPPER= 1E10 % % Lower bound for each design variable (bound in the python optimizer) OPT_BOUND_LOWER= -1E10 % List of available design variables (Design variables are separated by semicolons) % % 2D Design variables % FFD_CONTROL_POINT_2D ( 19, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind, x_Mov, y_Mov ) % FFD_CAMBER_2D ( 20, Scale | Mark. List | FFD_BoxTag, i_Ind ) % FFD_THICKNESS_2D ( 21, Scale | Mark. List | FFD_BoxTag, i_Ind ) % FFD_TWIST_2D ( 22, Scale | Mark. List | FFD_BoxTag, x_Orig, y_Orig ) % HICKS_HENNE ( 30, Scale | Mark. List | Lower(0)/Upper(1) side, x_Loc ) % ANGLE_OF_ATTACK ( 101, Scale | Mark. List | 1.0 ) % % 3D Design variables % FFD_CONTROL_POINT ( 11, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind, k_Ind, x_Mov, y_Mov, z_Mov ) % FFD_NACELLE ( 12, Scale | Mark. List | FFD_BoxTag, rho_Ind, theta_Ind, phi_Ind, rho_Mov, phi_Mov ) % FFD_GULL ( 13, Scale | Mark. List | FFD_BoxTag, j_Ind ) % FFD_CAMBER ( 14, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind ) % FFD_TWIST ( 15, Scale | Mark. List | FFD_BoxTag, j_Ind, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) % FFD_THICKNESS ( 16, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind ) % FFD_ROTATION ( 18, Scale | Mark. List | FFD_BoxTag, x_Axis, y_Axis, z_Axis, x_Turn, y_Turn, z_Turn ) % FFD_ANGLE_OF_ATTACK ( 24, Scale | Mark. List | FFD_BoxTag, 1.0 ) % % Global design variables % TRANSLATION ( 1, Scale | Mark. List | x_Disp, y_Disp, z_Disp ) % ROTATION ( 2, Scale | Mark. List | x_Axis, y_Axis, z_Axis, x_Turn, y_Turn, z_Turn ) % DEFINITION_DV= ( 30, 1.0 | AIRFOIL | 0, 0.10 ); ( 30, 1.0 | AIRFOIL | 0, 0.20 ); ( 30, 1.0 | AIRFOIL | 0, 0.30 ); ( 30, 1.0 | AIRFOIL | 0, 0.40 ); ( 30, 1.0 | AIRFOIL | 0, 0.50 ); ( 30, 1.0 | AIRFOIL | 0, 0.60 ); ( 30, 1.0 | AIRFOIL | 0, 0.70 ); ( 30, 1.0 | AIRFOIL | 0, 0.80 ); ( 30, 1.0 | AIRFOIL | 0, 0.90 ); ( 30, 1.0 | AIRFOIL | 1, 0.10 ); ( 30, 1.0 | AIRFOIL | 1, 0.20 ); ( 30, 1.0 | AIRFOIL | 1, 0.30 ); ( 30, 1.0 | AIRFOIL | 1, 0.40 ); ( 30, 1.0 | AIRFOIL | 1, 0.50 ); ( 30, 1.0 | AIRFOIL | 1, 0.60 ); ( 30, 1.0 | AIRFOIL | 1, 0.70 ); ( 30, 1.0 | AIRFOIL | 1, 0.80 ); ( 30, 1.0 | AIRFOIL | 1, 0.90 ) |
July 17, 2022, 00:08 |
Wally Maier
Rep Power: 7 |
Hi Zahra,
Why doesn't it work anymore? What happens in the simulation? How many points along the airfoil are present in the mesh? You should only need to change the DEFINITION_DV, though the config you posted does not have 25 design variables ( I count 18). Wally |
July 21, 2022, 18:58 |
#3 | |
Zahra
Rep Power: 4 |
Thank you so much for your reply. The point is that I have produced a mesh, and when I run the optimization with my mesh, I can achieve 44 designs, and the code works when I define design variable points every 5%. So when I have : DEFINITION_DV= ( 30, 1.0 | AIRFOIL | 0, 0.05 ); ( 30, 1.0 | AIRFOIL | 0, 0.10 ); ... it works. But with the same mesh when I change the point to DEFINITION_DV= ( 30, 1.0 | AIRFOIL | 0, 0.10 ); ( 30, 1.0 | AIRFOIL | 0, 0.20 ); ... or DEFINITION_DV= ( 30, 1.0 | AIRFOIL | 0, 0.04 ); ( 30, 1.0 | AIRFOIL | 0, 0.08 ); ... It does not work and diverges after three designs. The GNORM will be 1.912584E+124. and the direct simulation of the final design diverges. Is there anything that we have to consider for mesh generation? Or anything that we have to change as well as the "DEFINITION_DV" when we want to change the design variables point? Many thanks again for your reply Zahra |
dv_definition, optimizaion, su2 |
Issue on the design change when using the Ansys FLUENT adjoint-based shape optimizer | zyao1 | FLUENT | 0 | December 4, 2020 10:56 |
Change foamLog for Pimple iteration and new variables | Magistrane | OpenFOAM Post-Processing | 1 | April 26, 2019 05:26 |
Component update can be performed only in base design point | Domenico83 | CFX | 0 | March 10, 2017 06:48 |
JOB: Sr. Thermal/Mechanical Design Engineer | Dee Dee Dial | Main CFD Forum | 0 | April 1, 2003 19:49 |
CFD - Trends and Perspectives | Jonas Larsson | Main CFD Forum | 16 | August 7, 1998 17:27 |
