pitching amplitude increment UDF build problem in SU2 |
Qiulin
Rep Power: 4 ![]() |
I am an SU2 user simulating config_incomp_turb_sa.cfg. I would like to define a UDF to simulate an airfoil vibration dynamics.
the original configuration feature is: GRID_MOVEMENT= RIGID_MOTION MOTION_ORIGIN= (0.25 0.0 0.0) PITCHING_OMEGA= (0.0 0.0 14.91675) PITCHING_AMPL= (0.0 0.0 8.0) The pitching amplitude is a fixed number. however, in my simulation task, i would like to build a UDF to show an increasing pitching amplitude, which depends on the value of the current timestep. I would like to know if there is a related testcase that shows how a UDF is written. Thank you very much. |
su2 |
SU2 parallel install build from source failed | steadyman | SU2 Installation | 19 | April 25, 2021 16:50 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
UDF for pitching and rotating airfoil | guidofrate | Fluent UDF and Scheme Programming | 0 | November 20, 2014 08:32 |
Problem with my udf | july | Fluent UDF and Scheme Programming | 3 | June 20, 2010 06:56 |
